Bricked YP-Z5F needs help.
Old 30th Jun 2009, 7:09 pm
Exclamation Bricked YP-Z5F needs help.
Hi!
Unfortunately I've formatted my YP-Z5F to NTFS today and now it won't do anything besides I can put the device on HOLD position (the lock sign shows up) or just the the SAMSUNG logo simply shows up doing nothing.
I tried to put the device to UMS mode by pressing the "BACKWARDS" button while connecting it to the computer, but no I had no luck. Resetting the device only really resets it. I only can restart the whole procedure with it.
Also, I managed to put the device into "Player Recovery Device Class" state, but if I tried to flash, or update the player's firmware (with anything, or with the appropriate one), the software says it was "Unable to write firmware file data."
I'm running out of ideas, besides it would be adequate if I could somehow low-format the player's flash memory. Oh, and I managed to disassemble the device, tried to short circuit the pins, but it's no use.
Do somebody has any idea how could I revive my player?
rocket
Old 30th Jun 2009, 11:00 pm
Format it back to FAT32.
Old 1st Jul 2009, 3:16 am
Thanks, that's the best idea I could ever come up with. :-)
But, please tell me how I can do that, I can't manage the device to get recognized as a regular SCSI device via USB.
I plug the cable into the device. Connecting the USB cable to the PC does nothing. All I can do is pressing the SELECT button to set the device in Recovery Mode.
Can you help me?
Thanks.
Old 1st Jul 2009, 4:16 am
try looking here for help:-
Samsung Z5 - abi>>forums
Tags
bricked, samsung z5f, ypz5f, z5f
My ONDA VX858LE 2Gb clone has the screen in mirror, bricked! Mathiewoo Dead Players 0 27th Apr 2009 10:34 am
Bricked MP4 player (OEM KG216) Pappa Smurfer Dead Players 0 29th May 2008 3:36 pm
Bricked VX858 LE Knock-Off Help ronb1964 Dead Players 0 30th Dec 2007 10:47 pm
i think i bricked my mp4... pls help im desperate... jmm0070 Dead Players 3 23rd Sep 2007 7:58 am
Need Help- bricked my player evimarn Dead Players 4 14th Apr 2007 10:27 am
