[solved] Fake iPod Nano, works but wont connect on XP - 'unknown device'
Hi, I have a fake iPod Nano III. It turns on, charges, and works fine - I just cannot get my PC (Windows XP) to recognise it, 'Unkown Device' in Device manager is all I get, and I also get 'One of the USB Devices Malfunctioned ....etc' I can read on the screen of the device that the Firmware Version is: 2007/06/06 9.1.52 RADIO_AK1025 2007/05/15 and Memory is: 3906m I have followed instructions to install the adfuupdate.inf file (including the bit about driver signing - from My Computer/Properties/Driver Signing) - but I simply get 'The Specified location does not contain information about your hardware'. I have also noted the thread about changing the VID and PID values within the adfuupdate.inf file, but when connected the details tab simply reads: USB\VID_0000&PID_0000\.................etc. I've not followed the 'Recovering a dead MP3 player' (ie shorting out a chip) as its not dead, simply not recognised by my PC. Hope someone can help. Trebor. |
Have you tried a different USB cable instead?
Sounds like either a faulty USB cable or one of the pins on the player's USB connection is faulty so while it charges the player, if ONE pin is faulty/damaged, you will get that "Unknow Device" message. |
borken cable
Hi,
Thanks for your reply - its solved ! Yep, after two days reading this website, identifying my device, finding out about 'dead' players, and whats the correct firmware ... it was a broken cable ... you get what you pay for, I used a friends genuine iPod cable to check - and it worked fine ... the cheap cable that came with the device was faulty, upon opening the casing of the cable the - end that plugs into the fake iPod (ie the wide end) was found to have large blob of solder touching the metal casing of the plug, a piece of sellotape placed on the metal casing solved the problem. The cable soldering was very primitive indeed ! |
Glad it was a faulty USB cable and your problem is now solved.
Usually the easiest solution is the best one to try first (me, I'm just lazy so I would prefer to try the quickest solution!). You can pick up a USB cable pretty cheap anyway as well. |
Its never worked since I had it out the box, until yesterday, didn't think it could be something as simple as a cable - I can listen to my Pod Casts at last !!
Thanks :rolleyes: |
| All times are GMT -7. The time now is 12:00 pm. |
