25th Apr 2010, 3:32 pm
Originally Posted by vicioster
is that I do understand if among the webcam mode and I successfully uploaded the firmware qeu em let me just do not work with my player but I now turn respond repdroductor buttons and the screen is inverted, in a nutshell this firmware does not help me but I thank you if you have one for this model. if it will help the chip is Sunplus spmp3052a-hl171 and to start the boot mode I have to push a button that is hidden within the board just below Headphone input
se ve que no me haz entendido si entre al modo webcam y he subido correctamente el firmware qeu em dejaste solo que no me funciona con mi reproductor ahora enciende pero no me responden los botones del repdroductor y la pantalla se ve invertida, en pocas palabras este firmware no me sirve pero te doy las gracias si tienes otro para este modelo .si sirve de ayuda el chip es sunplus spmp3052a-hl171 y Para iniciar el modo de arranque tengo que precionar un boton oculto que se encuentra dentro de la board justo debajo de la entrada de auricular
i've give you the right firmware you need to upload it whit frm pro if this firmware thas'nt work for you
please give me more info about your player
board id, camera id,lcd id
thank's
