SomeBody Help Me pLzZz ?!
Old 10th May 2010, 12:28 pm
Exclamation SomeBody Help Me pLzZz ?!
SORRY for bad english
my china mp4 player isn't working anymore
when i open it
it just hangs up on the loading screen
"Loading....."
dunno bout it's Chip And Board Codes !?
what should i do !?
and is the saved files there will be gone ?!
plz help me ?!
Old 10th May 2010, 12:33 pm
it looks exactly like this
except the brand of LCD
mine is SONYClick the image to open in full size.
Old 11th May 2010, 8:58 am
WIZARD's Avatar
Exclamation Firmware
1) Figure out what chip is inside your player (Rockchip/Actions/Sigmatel/etc.)
2) Use "Google Pictures", find the player which looks like yours,
and then try to find the firmware for this player with similar appearance
3) Follow the "Dead Player Recovery Guide": Dead Players
P.S. For 1): to do that, use the program (i.e. ChipGenius) or carefully disassemble your player -
there are some numbers and letters written on a chip.
After you've completed the 1), tell this information to us: it will be easier to help you.
Try to play !
Old 12th May 2010, 4:04 pm
Default ahm !?
i'll try get those !
my player looks like the orange one !
even the color is the same !
ahm !?
can i get the chip code easily !?
and before i forget !?
the windows or PC doesn't
read my player !?
hows that !?
Old 16th May 2010, 4:46 am
WIZARD's Avatar
Exclamation
Originally Posted by kenjie View Post
the windows or PC doesn't read my player !?
Read the first post of this guide: DEAD PLAYER RECOVERY GUIDE
I hope it will help you to make your player recognizable!
Try to play !
Old 17th May 2010, 3:05 pm
got it Mr,Wizard !
but how about my files?!
will it be erased !?
or will it be gone ?!
tnx
My mp4 ipod (china) HELP...! plzzz davedevil Dead Players 1 13th Dec 2008 2:24 am
s1fw, plzzz, give me this fw from your site: Tyfon Firmware 7 26th Nov 2008 12:29 am
Plzzz help me atomkarinca Dead Players 1 3rd Mar 2007 12:32 pm
plzzz...i have problem to search my firmware lan Dead Players 0 9th Aug 2006 8:36 am
