-   -   3" 16GB Rockchip 2705 Firmware HELP! (http://mympx.org/forum/dead-players/45437-3-16gb-rockchip-2705-firmware-help.html)
TH_Overkill 7th Jul 2010 1:44 am
1 Attachment(s)
Hi all,
I think I need a firmware for a 3" 16GB (Might really be a hacked 4GB) Rockchip 2705 purchaced from TinyDeal.
The full story:
I have a 3" 16GB Touchscreen Rockchip 2705 MP4 player that I need help with.
I think it was hacked to look like a 16GB because it would not take more that 3.8GB of files.
I tried to fix it with RK27 Device Manager, I used the restore button and now when I plug it in to the computer I see 4 drives of 0 bytes.
The RK27 Device Manager still finds my MP4 player but when I try to update it, it says that it's the wrong firmware (I think because its for the 2706) and if I try the Restore button again it says "Format Failed"
I did backup the firmware before I did anything, but I don't know how to put it back on the player.
Thanks for looking
lolita 8th Jul 2010 3:40 am
Make a single 4GB partition or format it as one big (FAT32) disk, I'm not sure which type your player will accept.
TH_Overkill 8th Jul 2010 7:02 am
Hi, thanks for the reply.
I have tried to format it but I just get errors, It comes up in My Computer as 4 drives of 0 byte size.
I have read that when you restore these mp3 players the computer will no longer recognize them and you have to install a driver, I wonder if I need to update the driver so the computer recognizes it properly ??? Sometimes it comes up as an unknown device.
So maybe I need a driver for a Rockchip RK2705.
TH_Overkill 8th Jul 2010 11:22 am
I think i'll just sell it on ebay :)
