Mp4 player only works when under charging or plugged in pc
Old 1st Oct 2010, 6:55 am
Default Mp4 player only works when under charging or plugged in pc
Hi!
So i have a problem, the mp4 player won't turn on, i can only use it, if it's been charged, but when i plug it out from the wall charger, it turns off automatically.
The PC recognize the player, but same problem, when i plug out from pc, the player turns off.
Any idea?
Old 1st Oct 2010, 1:19 pm
Hi, I had the same problem, until I held the on button for longer because someone distracted me, try holding it down for 8-10 seconds, it may turn on. Hope this helps.
Old 2nd Oct 2010, 12:39 pm
Hi!
There is a switch on the top of the player with ON/OFF.
So i can't hold a button...
Old 5th Oct 2010, 4:44 pm
So when it plugs into the computer, you can turn it on and use it as per normal?
It sounds to be a HARDWARE problem than anything else.
I think the battery isn't connected properly, or has disconnected from the board, so when you're charging the player, the charge doesn't actually go to the battery so the battery isn't charging at all. Your USB cable and connection on the player is working fine because you can turn on your player when plugged into your computer and your computer picks it up fine so it tells me all the connections on your player's USB port is working fine. I'm thinking the solder or the connection has either broken off or isn't connected properly. Can you open up your player and take a look?
Windows reboots when mp4 player is plugged in misterk72 Support and How To 3 30th Nov 2008 12:52 am
player does not turn on. Plugged in it runs normally mymoonica Dead Players 3 12th Aug 2008 11:51 am
Windows doesn't recognize player when plugged into USB careymac Support and How To 11 27th Jan 2008 10:35 am
Speakers do not turn off when headphones are plugged diegux Mods and Themes 3 21st May 2007 4:52 pm
MP4 works only when charging joks7 Dead Players 6 6th Oct 2006 10:46 am
