How do I figure out that the serial numbers are?
Old 26th Nov 2010, 1:47 pm
Unhappy How do I figure out that the serial numbers are?
Hi Folks,
I have taken apart my MP4 player and had a look at the inside to get all the numbers/letters out (much to my wife's disgust, no faith at all!) And I have found:
Chip
ATJ2237T, ZB3KAC C41 - now i figured out it's an Action chip and that the next number is the serial number.
Camera
BS3403A - I have seen this number elsewhere in another post/thread/forum, so i think it's correct.
Board (had the name BKEESTAR on it)
BP128_V8.1
2009-1222ye
1017
LCD
SX2.8-CPT-3225A
20100531 (LDH)
It loads to the main screen, is recognised by the computer and opens it's window. the MP4 then refuses to take any commands, and after 10 seconds goes white and disconnects from the computer. WAAAAA! I have installed MP3 player upgrade tool, but nothing shows up and there are new files to upgrade to. Where do I get them from?
Thanks for your Help.
Col
Tags
chip numbers, firmware, upgrade
Can't figure out how to use the Ebook function diginetic Support and How To 2 6th Oct 2009 6:36 am
Samsung and Hynix Nand Flash Sizes and Serial Numbers tadad1 General Discussion 47 11th May 2008 6:20 am
I can't figure out the problem with my mp3/mp4 cescfabregas4 Support and How To 0 3rd Apr 2007 12:40 pm
I can't figure out the problem with my mp3/mp4 cescfabregas4 Support and How To 0 3rd Apr 2007 12:39 pm
Memory Chip Serial Numbers (Found THe Link) ashley_rb General Discussion 0 17th Mar 2007 11:29 am
