Philips Aria Not Detected!
I Have a Phillips SA1ARA04K/97 MP3 player which i bought last year. It was working fine, but all of a sudden its power went off and a white screen is displayed when it is put in charging. At First When I Connected It To PC, I Recieved 'Found New Hardware ' Message. The Found New Hardware wizard detects ROM Recovery Mode and HID-Complaint device.
The Two Devices Highlighted Appear In The Device Manager. ImageShack® - Online Photo and Video Hosting Only White Screen Appears When The Player Is Put in Charging. I Will Be Very Grateful To Anyone Who Helps Me Resolve This Problem.;) |
Dowload firmware , install they, then press vol+ and without releasing the button to connect the laptop, Recovery manager device must detect they, push recovery. Then the player must recoverю =)
If it does not, I can help you
Thanx!!!!!!
Thanx!!!! a ton
It worked flawlessly! You're awesome! |
Re
The Problem Still Exists!
The Philips Go Gear stops working as soon as i disconnect the usb cable. When i connect the USB Cable again, it again says that you need repair the device! |
Re
Re
How to charge Directly?
Please Elaborate. |
| All times are GMT -7. The time now is 12:30 pm. |
