white screen problem
Old 25th Mar 2012, 5:11 am
Default white screen problem
hello
Sorry for bad English
I have Ramos T8 have similar mp4 player
I installed the wrong firmware, and gave the white screen error
My computer does not see device
please help
mainboard info:
CR43TFTPMPV1.4
20081216
0943
ex original fw info :
Major version ID 1.1 and Firmware date is 090518.
Old 25th Mar 2012, 10:15 am
You need the RK27xx repair tool to make your computer see the PMP.
here:-
http://mympxplayer.org/rk27dm-repair...706-df947.html
You also need a copy of the original firmware from the player, and apply it to your player with the tool, other firmware versions
will not work as Ramos often change the hardware configuration on the players and
then change the firmware to match, Onda are known to do the same trick. :
Good Luck.
Old 27th Mar 2012, 2:39 pm
thanks knob
this program is working. my computer see again my pmp. but just like usb memory
i can't try intall new firmware because restore & update buttons not active. what can i do
Old 28th Mar 2012, 10:42 am
Have you got the firmware?
There is one to try here:-
[?] CR43TFTPMPV1.4 20081216 2705UFK 94V-0 4.3? - ? - ?-
Use button "Show System Disk" open your firmware partition and then copy folders over.
Download rk27_TestUsbHandler.exe - MyMPx
Old 29th Mar 2012, 4:00 am
i think my problem is the system disk. because i can not see the system disk
another way?
Old 29th Mar 2012, 11:11 am
Use rk27_TestUsbHandler.exe to get your player into Rkusb update mode.
and then
Try loading the firmware folders using this tool:-
http://mympxplayer.org/rockchip-rk27...v25-df881.html
The tool should recreate the partition for you.
Old 27th Jul 2012, 12:14 am
If you’ve tried all three of these steps and the problem still isn’t fixed, you’ve likely got an issue that you can’t fix.
white screen on boot up ... or screen splits into four superpexxx Dead Players 6 29th Jan 2009 12:14 am
White Screen mp4player84 Dead Players 3 25th Feb 2008 5:17 pm
Screen blinks and only a white screen oxidonitroso Dead Players 1 15th Sep 2007 2:38 am
Screen just goes white. FourJacks Support and How To 14 6th Sep 2007 11:44 pm
Glacier - Screen white then flickers then white again clackers91 General Discussion - Uxcell.com 6 2nd Mar 2007 3:21 pm
