Firmware upgrader for samsung k9l8g08u0a
Old 21st Feb 2008, 1:59 am
Default Firmware upgrader for samsung k9l8g08u0a
hi, i'm a newbie here, i have a player with samsung k9l8g08u0a firmware, it has 4gb capacity, but the files are corrupt when i put large amount of (movie) file.... can anyone help me please.......
Old 21st Feb 2008, 7:59 am
Default Re: Firmware upgrader for samsung k9l8g08u0a
Hi Kewlot,
Samsung k9l8g08u0a is memory chip of your player and k9l8g08u0a shows that is 1GB not 4GB. Please read thread How To: Removing Memory Hack
Old 21st Feb 2008, 9:39 pm
hi unsal, thanks for d reply, it really worked... now i know infos from this forum.informative....
but i have 1 problem, i have usb 2.0 flash drive with the same firmware... i tried the tool but it didn't work... is there any tool for usb drive to remove the hack tool?
thanks!
Old 22nd Feb 2008, 6:03 am
Hi Kewlot,
there is a tool to format usb disks having iCreate controller chip. Its name and version is iFormat ver 1.32. I think your usb has a iCreate chip because it is easy to hack it. If you can find that tool, try it. if you can not, inform me so that I can send you later.
Old 22nd Feb 2008, 6:27 pm
hi unsal, my usb is named sony, but i think its made in china,a fake one, it has microvault label outside, but when i downloaded the utility from sony, it doesn't work right, so it's a fake. coz of that stupid hack, 4gb but it's the same as my mp3 player, after i put files on it with more than 1gb loads of files, it's file corrupt... i guess it's 1gb only.. so i decided to open a partition manager and resize my usb drive to 1gb only. that's all. working fine. Thanx for your help unsal! more power!
I need the firmware for SAMSUNG 716 seba_carr Support and How To 1 14th Nov 2007 4:42 pm
Samsung 704 K9L8G08U0A-PCB0 help me please fifou666 General Discussion - Uxcell.com 0 30th Oct 2007 9:40 am
Looking for firmware: 3.5.37 SAMSUNG 634 stephen1705 Dead Players 0 31st May 2007 3:32 am
FIRMWARE mp4 samsung 652 crakpa Dead Players 1 5th Apr 2007 7:32 pm
NEED firmware for Samsung 638 chickenclaws Dead Players 2 22nd Nov 2006 1:02 pm
