-   -   Any one extract the ACT2093 S75 for ATJ2093H and upload it ? (http://mympx.org/forum/firmware/40737-any-one-extract-act2093-s75-atj2093h-upload.html)
yahallaq 11th Mar 2008 11:14 am
hi every one
i have mp4 player ATJ2093H but it's dead
after resolving it's problem it's now in ADFU mode and it's needs for
firmware version .
the firmware is ACT2093_S75 , I searched for it in the internet for 7 dayes and i didn't find it :roll:
if any one have the same device and extract it's version and upload it at any link and put it here :( .
i'll be very pleased for that .
you can use s1fwx tool to extract your firmware
zrock 13th Mar 2008 11:52 pm
yahallaq, your player would be using the v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
As there is no way of telling which firmware would work with your player, you'll need to try all of them.
Good luck.
yahallaq 14th Mar 2008 4:17 am
Thank you zrock,
but i have tried most of them and no one give result,
it seems need the same frame ware that was on it
ACT2093_S75
this is a picture of it
http://www6.0zz0.com/2008/03/12/21/101356286.jpg
