help me please to format my mp3 player
Old 13th Mar 2008, 12:30 pm
Default help me please to format my mp3 player
hi
after have upgrade my mp3 player (fake sony) with firmware "Firmware_9.0.50_Monochromatic_LCD" when i have to format it i have error message "whrite protect" whitout activing my hold bouton .
please help me to format it :roll:
Old 13th Mar 2008, 11:34 pm
Upgrading a new firmware to a working players is not advisable.As long as its working,don't upgrade it.
Try formatting using Mp3 Utilities Disk Tool.
If it doesn't work,its a firmware problem.Maybe the firmware you have used to upgrade is corrupted or its not "too" compatible for your player.
Old 13th Mar 2008, 11:35 pm
Default Re: help me please to format my mp3 player
Old 14th Mar 2008, 4:30 am
Hi
I Try using formatting Mp3 Utilities Disk Tool.
GT but the same problem.
I remind you that I use the firmware
Firmware_9.0.50_Monochromatic_LCD "I download onto mymxplayer.
Please help me
Old 14th Mar 2008, 4:54 am
Hi
Question: Why do you want to format the player?
Try the HP Formatting Tool, you'll find it here: http://files.extremeoverclocking.com/file.php?f=197
I know it looks like the Windows format tool, but beleve me it's not. This will erase everything, including the firmware. So you'll have to reinstall it after formatting. Hope it helps. Good luck
P.S. If your player's memory is below or equal 2Gb, use FAT sistem
Old 14th Mar 2008, 6:04 am
Hi again, I just used it on my mp4 and it didn't erase the firmware....just formatted normally. Hope it works for you too.
Old 14th Mar 2008, 6:57 am
hi
thank you but it doesn't work.
please help :roll:
Old 16th Mar 2008, 7:51 pm
arbaoui5,its a firmware problem.Shorting the pins and flashing a new firmware(back up firmware of your player) will do the trick.
Old 17th Mar 2008, 3:19 am
hi
thanks zrock .I am looking tools, and I will try.
I bear aware.
:P
How to convert videos to MPEG4 (avi) format? Invalid format? makenna29 Video related 2 19th Feb 2009 1:25 am
[solved] format error/wrong video format... isaac556 Support and How To 2 6th Sep 2008 7:14 pm
difference between a full format and a quick format? jade7 General Discussion 2 7th Aug 2006 9:36 am
Should I format the player right when I get it? Rocker81 Support and How To 3 29th Jun 2006 8:55 am
why does the PC ask to format the player? techkrazy Support and How To 1 23rd Mar 2006 12:48 am
