-   -   As usual, firmware needed (http://mympx.org/forum/firmware/40760-usual-firmware-needed.html)
Abandonio 13th Mar 2008 4:44 pm
Hi everyone, I just KILLED my chipod trying to get ride of its really ugly FW looking. I was inexpert and silly enough to do not make a backup first, so... if by any chance anyone holds a chipod with some close board, I would give it a try. Thank you. May I find solution anywhere else, I would post it. Good luck friends.
Abandonio 13th Mar 2008 5:06 pm
Oh... I forgot, It looks like this one: http://www.mympxplayer.org/full-firm...are-df324.html
However, the board may be diferent, since its FW did not solve my problem.
zrock 13th Mar 2008 11:28 pm
Abandonio,you need to disassemble your player and look for board numbers.Chipod players have the same firmwares in terms of graphics and designs but different in board compatibilities.
Abandonio 14th Mar 2008 6:13 am
Re: As usual, firmware needed
I think the model of my board is this one, as no other numbers are to be found inside the chipod: JTH-MP3-801(B)V3.0 Thanks in advance for any clue. Good luck everyone.
zrock 14th Mar 2008 10:42 pm
Is your players RAM chip an Action or Rockchip?
Abandonio 15th Mar 2008 6:20 am
Chip number
Hi friend: first of all, thank you for taking the time to help me out. Inside my unit I did not see any other reference than the forementioned number on the green pbc, and the numbers onthe chips. They are the following: ATJ2085W, inside in the front when you open the chipod, and SPT SP3767HN (06CS03) in the back. I hope this can tell you (so you can tell me) the maker or model of this chips. In any case, thank you in advance.
mnfdz 15th Mar 2008 8:55 am
Hi,
(please its very urgent) ther is some one can help me ? I realy need this Firmware its fo Zic Vmax 512mo....
please help me my friend.
zrock 16th Mar 2008 7:39 pm
Abandonio,
Have a look of s1fw post here:
http://www.mympxplayer.org/s1-mp3-pl...et-vt8747.html
Then try to find your firmware here:
www.s1fw.com
Then if still you haven't find your firmware,maybe you should try all the version 3.xx.xx firmwares that can be found on the download section.Theres no guarantee which firmware will work for your player its up to try them all.Give it a shot.
Goodluck!!
