Need firmware QY-066FVO 真(HC190-01AR)?? AK1025
Old 18th Apr 2008, 9:15 am
Thanks, Zulu, but there it was the atj2091, again. I need the ak1025 one. Where could it be??
Old 23rd Apr 2008, 4:57 am
have similar m4 player. 8Gb. "Glacier" type.
White screen on start.
memory chip: HY27UT08862M
board version: QY-066FV0 2007.05.11
chip: AK1025
screen label: 080202LKD-T1.9-4
screen connecting cord: LDC-T200005-V3
I tried with all the firms in the all dirs with AK1025 firmware. About 50 items...
If you find working firmware, please, send me link for this firware.
Old 23rd Apr 2008, 10:25 am
Ok, i will. Same to you, if you find something usefull, let me know...
Old 9th May 2008, 4:09 am
I had the same MP4. I still not found a working FW for it. Luckily I found that it can be recovery by flash 2 FW files respectively. It sound strange but it work for me.
First, Flash your MP4 with this file.
http://www.uploadd.com/download.aspx...D3221NSISI6RK9[ASNA4M
After flash, your MP4 should be show white screen. PC can detect your MP4 as USB disk.
Second, Flash it with this file.
http://www.uploadd.com/download.aspx...UH5GM5SVA1QJ8U
Then you are done. Now your MP4 should show sand watch for a while. Please wait.
The software I used is "MP3 Player Product Tool 5.11".
Old 14th May 2008, 10:43 am
Could you explain a litlee more about your system?? You said:
Flash your player. Does that mean that i should try to recover with that firmware?? and then i should recover with the next? What is Flash for you?
Another important thing. Could you please upload those firms in another server?? Right now they give less than 1kb/s, and it still break. I have tried many times...
  #16 (permalink)
Old 21st May 2008, 10:30 pm
Sorry for my bad english which make confusion.
Let me tell you the whole story.
I had bought this MP4 from ebay. Just only a day since received it, It hang and stuck with sandglass. I had searched info on internet and try many FW including all suggested overhere. But no any FW worked.
However with some luck, I found that 2 FW can recovery my MP4. I 'm quite sure that you already try either one or both of them. Here is new link.
**You may need to put your MP4 to ADFU mode before start following step.
1. Recovery your MP4 with this FW.
http://www.mediafire.com/?j09ethnql2t
2. Turn OFF and ON your MP4. Now MP4 should show white screen and PC detect it as USB disk. You may also need to format your MP4.
3. Recovery it again with this FW. This FW is actually for 2091. But it work on my MP4(AK1025).
http://www.mediafire.com/?2azfgamivjf
4. Turn OFF and ON. Now MP4 should show sandglass. Wait for a while, your MP4 should be alive.
My MP4 detail.
Chip:AK1025
Mem Chip: 29F8G08MAA
Radio Chip : SP3767
Board : QY-066FV0 2007.05.11
LCD : 2", can not find part number on it.
  #17 (permalink)
Old 5th Oct 2008, 9:46 am
My MP4 detail.
Chip:AK1025
Radio Chip : SP3767
Can you upload the files again please? i tried to download it from ther firts server but i couldn't and when y tried with the other server it says that the file doesn't exist
Looking for firmware AK1025 9.0.50 marocsoldiers Firmware 0 7th Jul 2008 11:19 am
Looking for AK1025, ATJ2091H, AK1025, ATJ2085 and AK1025 Zulu007 Firmware 8 5th May 2008 10:30 pm
Looking for firmware AK1025 qy-066fvo 2007.05.11 tomas19lt Dead Players 8 4th May 2008 8:46 pm
Looking for firmware: AK1025 qy-066fvo 4GB hakan38 Firmware 7 5th Apr 2008 5:37 am
need firmware ak1025 reymisteryo Firmware 3 3rd Apr 2008 5:31 am
