Looking for firmware t_93_15_5ka 06/09/2006 act_v90.48
Old 24th Mar 2008, 5:25 am
Default Looking for firmware t_93_15_5ka 06/09/2006 act_v90.48
Hello friends
I am looking for a firmware for my mp3 player
exactly this one
------- mp3 player t_93_15_5ka 06/09/2006 act_v90.48 ----------
Please Help me the player is not mine
Thanks in advance.
Old 26th Mar 2008, 2:19 am
Hi moumen,
Have a look at this post here: http://www.mympxplayer.org/s1-mp3-pl...et-vt8930.html
See if you can find the firmware from there.
Good luck in your search.
Let us know how you get on.
Old 26th Mar 2008, 3:07 am
moumen,disassemble your player and post all the infos inside on it here:
Old 27th Mar 2008, 5:43 am
Thanks for you both ADMIN and ZROCK
I will do what you recommend me to do, and even if the player will not work, I would be very grateful for you reply
Old 31st Mar 2008, 2:48 am
Default Re: Looking for firmware t_93_15_5ka 06/09/2006 act_v90.48
Hi all of you
I know I am late, the owner told me that I have ONLY one week to get his player working,
So I Dissambled it and I found this letters :
HH91St-1025C-G2008
25-11-2007
That is all what I found,
Another question : My friend has a mp3player like mine but it's not the same disk space storage
Can I extract Its firmware and then flash my player with it ?
Old 31st Mar 2008, 10:59 pm
current extracting tools support only version 3.xx.xx firmwares and theres the latest version 9.0.43 extraction tool but still buggy then and your player uses version 9.48 so you can't extract it and use it.Is that all info you can give bout your player?Look for the RAM chip if what type is it.
Old 5th Apr 2008, 1:32 pm
Hi friend ZROCK I am very grateful,
I am sure it's alla that I can find un the PCB,
So any solution It would be very usefull
Thanks in advance
Looking for firmware, QY-030FV1 2006.12.16 waldopulanco Firmware 2 19th Jan 2009 4:50 pm
Firmware act2097_s7_1 (2006/03/11) cmsasr Support and How To 2 7th Jan 2008 1:43 pm
Dead player, looking for ATJ 2097H ACT_V90.48 andymcnab65 Dead Players 3 11th Oct 2007 9:09 am
Need Firmware 9.0.50 2006/10/30 garfield Dead Players 0 23rd Jan 2007 11:14 am
Firmware for ACT.V3.5.35 / SC85051E /2006/04/07 anchor2006 Support and How To 0 14th Oct 2006 11:32 pm
