Dead MP4. ATJ2093N ZX 923M-TLS V2.0 2007 03 27 ROHS
Old 2nd Apr 2008, 9:46 am
Default Dead MP4. ATJ2093N ZX 923M-TLS V2.0 2007 03 27 ROHS
:cry: Hello, i hope, this forum get me to a sucsess upgrade to my dead mp4 Player.
My Problem is, that I try out a new firmware, but it goes bad. Now this player is shown on my PC as a Actions USB (HS) Winusb Device.
I try out several firmwares without any sucsess. The only thing I see, is a blue grey screen with a sandclock. My Player date are: Board ID: ZX 923M-TLS V2.0 2007 03 27 ROHS. The Chip is: ATJ 2093N. Memory is a 4GB Hynix Chip. I hope I can find out an answere here. When also this cry for help goes bad my player is even good for the trash. :cry:
Best regards from the Harz in Germany
Chris
Old 2nd Apr 2008, 5:56 pm
http://www.s1fw.com/Actions-ATJ209X/...3N-2-0-de.html
GOOD LUCK FOR YOU
Made in Shenzhen
Dead player
Old 3rd Apr 2008, 1:56 am
Hey s1fw, thanks for your quick answer!! But tried this several times without luck. I opened it also with the tool s1res.exe to try out some other settings but nothing works. I think that my chip is broken. But all the way I am going on to try out a few more firmwares. But all the way I post it here either I give up and put the player in the trash or if I am sucsessfull!!
Greetings an god luck for all the other peoples who buyed so bad players!
Old 3rd Apr 2008, 7:18 am
Fridolin,the firmware that s1fw gave you seems perfectly fits the board of your dead player.Is there a problem with the firmware when using it on upgrade tool?
Old 3rd Apr 2008, 7:46 am
zrock
it seems so, but it didn`t work! The only thing I see is the start screen dark blue grey with the sandclock in the middle. But I try out annother fw with the player and now I have a white display and after connect to the pc I have a new cd player and a flash drive with a size of 1.9 GB. Funny or??. That all say to me, that the chip is o.k. and only the firmware isn`t the right one. But I try on. After all I use the latest update tool MP3Utilities 5.09. Because in this tool there is the only working driver for the players usb device called: Actions USB2.0 (HS) Winusb Device. I am searchin`on. Thanks for writing me!!
Greetings
Old 4th Apr 2008, 5:27 am
Hello, do anyone of you can tell me, where I can search further the right firmware for my player. It seems to be an exotic one.
Thanks a lot!!
Old 4th Apr 2008, 5:51 am
http://www.s1fw.com/Actions-ATJ209X/...FM-070905.html
GOOD LUCK FOR YOU
Made in Shenzhen
Dead player
Old 4th Apr 2008, 7:01 am
Hi, s1fw, isn`t that the firmware you already postet to me?? I tried this out with several MP3 Utilities. Every time with the post of sucsess. But it dosnŽt work for my player. I am going to nirwana an throw my player right into hell and buy a new one. I think now that the chip is broken. Thanks a lot to the members who want to help me but at least nothing helps. Ok, so long and as I always said, good luck to recover worst made dead players from china.
Ciao
Chris
Old 5th Apr 2008, 6:39 am
Hey anyone here!! I MADE IT RUnNING!!!!. I took the last posted fw and I used MP3 Player Product Tools 5.15 to flash it and not the MP3Utilities 5.15. That was it. What a trip, but at least I can say that the time I spend on it was not for waste!!. Thanks a lot to this forum for givinŽideas for my way to recover a completely dead Player. Good buy from Germany / Harz
Ciao
Christian Erber
Old 18th Apr 2008, 1:14 am
Default Re: Dead MP4. ATJ2093N ZX 923M-TLS V2.0 2007 03 27 ROHS
hey buddy need yr help i v an mp3 player tats in d same condition as it was of yrs can u give me dlink from whre i can get d "MP3 Player Product Tools 5.15" plz do send d reply
heres my email id sures137@gmail.com
thanks in advance
player details
device name : LISONG MP3 PLAYER
productor : WILSON CO. LTD
version : 9.0.48
chipset : ATJ2091H
with SAMSUNG [640 K9G8G08U0M] 2 GB FLASH DRIVE
Looking for ATJ2091N PSQ82BC C5N board: MP3-910651 V:3 RoHS TheHouse Firmware 0 26th Dec 2009 5:25 pm
Looking for: Atj2093n ZX-6012M-TSL V4.0 2006.11.22 aveliz2008 Dead Players 6 10th Aug 2009 8:28 am
Looking for ATJ2093N ZX-6012M-TSL V4.0 2006.11.22 aveliz2008 Firmware 0 30th Jul 2009 7:21 am
Need firmware SinoWealth SH86280 Display: XY-1.8CCV2 (ROHS) valera_vv Dead Players 0 26th Jan 2009 3:35 am
Looking for firmware ATJ2093N samsung 713 K9G8G08U0M uyhasoft Firmware 0 3rd Aug 2008 9:29 pm
