need firmware for ak1025 player MPW-930313K V: 5
hi!
i've got a dead player and i need the firmware. now i have a white screen and i see only a removable usb memory device on the pc. can someone help me? the player (v9) has: chip: AK1025 memory chip: SAMSUNG 1GB mainboard: MPW-930313K V: 5 screen: YXD17720S07A (1.8 inch color display) FM radio thanks to everyone can help me Gioele |
http://www.s1fw.com/Actions-AK102X/A...51-070716.html
GOOD LUCK FOR YOU |
Re: need firmware for ak1025 player MPW-930313K V: 5
hi
i try to use your formware but the firmware upgrade tool (i've tried some different version) show an error: "The firmware's protocol is not the same as the previous firmware's, please exit the tool and select the firmware" how can i solve this problem? thanks |
gioeleg,just rename the firmware filename by deleting the unknown (Chinese)characters on it.Then use it again and it should work now.
:cry: i've tried the firmware but the screen is still white
i think this fw is for another display (70012) and my display is 17720 have someone another fw to try? |
| All times are GMT -7. The time now is 1:10 am. |
