-   -   please help (http://mympx.org/forum/firmware/41101-please-help.html)
agentjames 14th Apr 2008 10:26 pm
please help
Hi, i have an mp4 which appears like this http://cdrking.com/local/products/in...033341-4590494.
I have a cd driver but corrupted. i would like to ask for its firmware available here. I have browse everything on the net but havent found exactly as of my mp4 firmware version.
Please help, I am very much appreciate to anyone can help me..
Thank you very much...
Zulu007 18th Apr 2008 8:29 am
The link of the photo of your mp4 is not working so give the working link and also give the descriptions too of your player like what is the MAIN CHIP and what is the ID of the MAIN BOARD
admin 22nd Apr 2008 10:53 am
Hi agentjames,
Can you tell us exactly what is wrong with your player? Be as descriptive as possible please.
agentjames 2nd May 2008 4:35 am
Re: please help
Sorry for poor description i have before.
Well here's the pic, i hope it works.
http://img146.imageshack.us/img146/3718/sb118fz6.gif
I do not know where to find the main chip and id of the main board. The mp4 is properly sealed. I havnt open it since i bought it last year.
Originally Posted by admin";p=&quot (Post 48061)
Hi agentjames,
Well I tried to upgrade the firmware of my mp4 because when i try to open the music player it turns off. Well, about the battery its still in good condition, actually when i try to open the AMV player it plays normally.
So here it is now, i thought i could fix the problem thru formating it and re-install the firmware, well i did it i format it and re-install the firmware. Eventually, i just realized after re-installing the firmware that i used DIFFERENT version. Now my mp4 doesnt show any display on screen now, only the light bulb inside flashes.
So what should i do? should i open my mp4 to see the CHIP BOARD ID?. I have only remember the firmware used was SIGMATEL MSCN. The version of the firmware is too long havent memorize it. It goes like something like this (000.000.000.000). {i used zero for sample}
I hope i decribe the details well. Just tell me if i miss something..
Thank you very much for your help... looking forward for your response
tcu212 2nd May 2008 7:39 am
agentjames, try to ask cdrking to repair your mp4, their tech support can help you, or try to open your player.
agentjames 2nd May 2008 7:11 pm
Re: please help
I already tried many times, but according to them they dont have the firmware anymore. It seems they doesnt support it anymore even in their website its already been remove.
Well they give me an option, they said i have to visit their store for personal assistance. But i think it will cost me a lot..
tcu212 2nd May 2008 7:48 pm
download this one
http://www.mympxplayer.org/tool-chip...del-df834.html
plug your mp4 into your computer, then open the program, there you can see what firmware your using, then post again so we can help you
tcu212 2nd May 2008 8:44 pm
is this the same mp4 of yours?
http://www.mympxplayer.org/image-asp43.html
[strike:52e451956b]if yes, you can download the firmware here or posted in there
http://www.le-mon.com/Download%5CMPV920%5Cmpv920.zip[/strike:52e451956b]
link not working
agentjames 2nd May 2008 9:50 pm
[strike:352372def2]if yes, you can download the firmware here or posted in there
http://www.le-mon.com/Download%5CMPV920%5Cmpv920.zip[/strike:352372def2]
link not working
The figure looks the same but the firmware is different, and the buttons too. The bottons that my mp4 have is in front and in the right side only not like in the picture it has a big button in the left side.
tcu212 2nd May 2008 9:54 pm
this one??
http://www.mympxplayer.org/my-first-player-asp65.html
try downloading this one
