QY-066FV0 2007.05.11 T-0020-A
Please, help.
I need firmware for AK1025 QY-066FV0 2007.05.11 T-0020-A (1GB, there are no games). Thanks. |
try this one:
http://www.s1fw.com/Actions-ATJ209X/...-20071028.html |
Unfortunately ATJ2091N/LG-LZY-QY-066FV0-TFT70023-2091-V9-1-52-20071028 it is not necessary.
Player it is loaded, but does not see the flash a disk. |
can you on your mp4?
Before has flied firmware yes. Format AMV.
Now radio works only. |
well i think ALEXEY you are trying to say that you player is booting and shows the menu but anything related to flash memory is not working,just the radio is working............right?
Well if that is the problem then it can be solved by installing the firmware in it but first be sure that you have the right firmware. Secondly it is also possible the your flash memory is not working properly and for that you can consult the recovery guide as the TCU212 gave the link.........to reset the flash memory of your player . If then too it is not working that buddy i think your flash memory is busted and you have to change it but it is very complicated procedure. But see i hope that some thing work for you |
Yes, so. Shows the menu, but at attempt of the reference to flash-memory « the Mistake of a disk » writes. Though from a computer player it is defined as USB Flash Disk 1GB and on it it is possible to copy files.
All problem that at me is not present necessary firmware. I have tried more than 20 various firmware, including: LG_LWL_QY-066FV0_CM50016_AK1025_V9.1.51_20070706 QY--066-6key_50_2091_20_h_070608_tftld20 All Glacier Firmware http://www.mympxplayer.org/pafiledb/...a4e9d7ec2f1.7z LG_LZY_QY-066FV0_TFT70023_2091_V9.1.52_20071028 and only with LG_LZY_QY-066FV0_TFT70023_2091_V9.1.52_20071028.fw there was a menu, in other cases the white or black screen. It is necessary firmware AK1025 QY-066FV0 2007.05.11 T-0020-A (1GB, there are no games). Many thanks, for support. |
| All times are GMT -7. The time now is 9:10 am. |
