-   -   Upgrade wrong firmware, player die (http://mympx.org/forum/firmware/41300-upgrade-wrong-firmware-player-die.html)
denkhongduong 7th May 2008 7:19 pm
I have an Mp4 (sony S606) made in China, It uses firmware 9.0.52 wilson and chip AK1025. It was locked and I upgraded firmware which downloaded from mympxplayer. I used MP3 Player Utilities 4.00 to do and after it said "Upgraded successful" my player can't start and do not show anything on LCD. Now when I connect to PC, windowsXp do not recognize and ask for driver. I know It is in recovery mode but MP3 Player Utilities 4.00 can't find any player to do. what can I do now?
spam 11th May 2008 10:57 pm
Re: Upgrade wrong firmware, player die
read next
http://www.mympxplayer.org/dead-play...ide-vt567.html
admin 12th May 2008 12:53 am
Try using a different version of the MP3 Player Utilities to flash your player.
If that doesn't work, then you will have to try resetting the player as an ADFU Device then try to find a compatible firmware for your player by checking out s1fw.com.
notlate 12th May 2008 7:23 am
Zipy Koala, 1 GB file sys error
first thank you in advance
i have an mp4 zipy koala 1 GB china made, first i had a problem that the player works for 1 min then switch off, and i did a format then i had a new problem a msg on the screen it file sys error, dont know what to do plz help.
