31st May 2008, 10:00 am
I have been searching for the firmware with no luck.
I have found the following info inside the player (which has no screws, you have to push it out of the case if that helps identify the player any better):
Ak1025 7k110ABo L2
on the front of player it shows 80-2501 8*
**2997*01*28VER:A
On the other chip, under the sticker it shows:
NANDE12W3A2BD6
880DG 8Y
50P 88 547
On the board, it has printed:
80-2501B
1025 VerA
On the tiniest chip it shows:
SPI
SP5764AIIN10BAS05
Hopefully, this will help you find the firmware link I need. I seem to be unable to pull this info together to select the right one.
