-   -   Looking for firmware AK1025 7I002AB OIJ ATJ209X/ACU75XX/ATJ2 (http://mympx.org/forum/firmware/41580-looking-firmware-ak1025-7i002ab-oij-atj209x-acu75xx-atj2.html)
iretretrac 12th Jun 2008 11:26 am
I need help finding full firmware (I think)
my screen is white, and my player shows up as removable disc g
or a usb mass storage device in the device manager.
It is supposed to be a 4 GB mp3/4 player
4GB MP4 MP3 New Generation recorder player silver
The numbers I got were
AK1025
7I002AB OIJ
ATJ209X/ACU75XX/ATJ2063
and then
2007/02/18 ver:A
BO-15002
but when i look on the other side it says
2007/02/18 ver:A
BO-25002
and SAMSUNG 743
K9HBG08U1M
PCBO
FEI845P5
and I think the screen is
FPC018TSD23-20
QT SX VO1
it is also the 9.1.52
Can anyone please help me, I am trying and trying different things on my own, but i am afraid that i am going to mess it up more or break something.
thanks
admin 12th Jun 2008 1:18 pm
Hi iretretrac.
Take a look at s1fw.com and see if you can find it there. Just do a search for your chipset type AK1025 and see if you can find a compatible firmware for your player.
Good luck with it.
There is a member called s1fw which might also be able to help you as well.
iretretrac 12th Jun 2008 1:31 pm
I have been doing trial and error for three days now, and my husband takes over when he gets home from work.
I am going out of town, and I am trying to fix it before tommorrow.
There are soooo many files, and i wasn't sure if I was looking for the right numbers.
