Help Firmware for my MP4 Player
Old 9th Jul 2008, 10:55 am
Default Help Firmware for my MP4 Player
Can exactly you link me working firmware for my MP4 Player?
DATA:
1.8" - 2 GB
Samsung 734
K9LAG08U0M
PCB0
FEGB63BAC
ACU7503
G2079CA C20
Under screen: GY AA018
Under battery: ZHV0 9VEN 042030SP 3.7V 240mAH 08A
Near "joystick-keys" this:
B0-018T
**2007*01*28
7513 VER:C**
This is my MP4:
Thanks!!!
Old 10th Jul 2008, 7:15 am
http://www.s1fw.com/Actions-AK102X/A...-52-10-17.html
GOOD LUCK
Made in Shenzhen
Dead player
Old 10th Jul 2008, 12:17 pm
Default Re: Help Firmware for my MP4 Player
Thanks for your answer...
It completely doesn't work (upgrade failed).
Now I also read near "joystick-keys" this:
B0-018T
**2007*01*28
7513 VER:C**
Old 17th Jul 2008, 3:09 pm
Up...help me!
Old 30th Jul 2008, 2:19 pm
Up...please!
Old 31st Jul 2008, 6:40 am
http://www.s1fw.com/Actions-ACU75XX/...51-070725.html
GOOD LUCK
Made in Shenzhen
Dead player
Old 6th Aug 2008, 7:36 am
Thanks...but it doesn't work...with different MP3 Upgrade Tool the result is the same: "Invalid upgrade firmware file".
Old 21st Aug 2008, 3:12 pm
Up!
Old 22nd Aug 2008, 2:08 am
if you have visited the site that was linked and used any firmware on this site with no luck then you are out nof luck
there are so many different versions of these players from many different factories that odds are you will never find a firmware
truth is these players are not made for upgrading no matter what it says and finding working firmwares iss a nightmare that often ends with no luck, they are cheap for a reason im afraid
like i said, if nothing that was kinked worked and no download from this site helped then it sounds like a no go fix - sorry
Old 27th Aug 2008, 7:55 am
With some firmwares that I downloaded the player is recognized from computer (like removable disk), but I can only use it like removable disk and not like MP4 player becouse the screen is all white.
Then the problem only is "software" for the screen (I think).
