Hello pedro
here is my firmware:- http://www.mympxplayer.org/rk27xx-fi...-8r-df890.html here is another to try:- http://www.mympxplayer.org/rockchip-...-am-df898.html Use rkusb.tag for the above 2 firmwares The RAmos RM970 firmware can be got here:- http://translate.google.com/translat...hl=en&ie=UTF-8 If this does not work try this upgrade tool:- http://www.mympxplayer.org/rockchip-...v25-df881.html |
Thank you knob. I've tried all the firmwares but they did not work. At least they turned on the screen but it is all white. Now, I know that it is not physically damaged. Only the firmware (the most important part) is lost. :-(
RockChip
RK2706 7E05002 0812 Screen 4315U-080320-080323-06-30 another chip SAMSUNG 816 K9LAG08U0M PCB0 Another chip TAIWAN TM54S816T-7 |
this is a link to a firmware from the same company in china that also makes a version of the player you have
now it may be that that they uses similar hardware??? as they may have come from the same original factory worth a try also, have you emailed CDRking and asked them to try and extract a copy themselves and send to you, they seem hot on having downloads available http://pasen88.cn/admin/shangchuan/U...6014229847.rar |
http://translate.google.com/translat...sl=zh-CN&tl=en
quite a few bits on this web site, and i thin also knob, maybe a newer firmware for your player, they call it the k818, there is a download at the top of the page edit .. forget that knob, theirs seems to be an ingenics based version of this player!!!! also the seem |
sorry to hijack, just posting this for knob
http://www.qqmp4.net/show_products.a...=K%CF%B5%C1%D0 this player can be found on dealextreme for about $40, its ingenics based and that chinese firm seem to have a download for firmware for it, just thought you may like to know as a cheap route into ingenics players |
| All times are GMT -7. The time now is 9:21 am. |
