speaker does not work when it's in FM mode
Old 23rd Aug 2008, 5:10 am
Hello pedro
here is my firmware:-
http://www.mympxplayer.org/rk27xx-fi...-8r-df890.html
here is another to try:-
http://www.mympxplayer.org/rockchip-...-am-df898.html
Use rkusb.tag for the above 2 firmwares
The RAmos RM970 firmware can be got here:-
http://translate.google.com/translat...hl=en&ie=UTF-8
If this does not work try this upgrade tool:-
http://www.mympxplayer.org/rockchip-...v25-df881.html
Old 23rd Aug 2008, 5:49 am
Thank you knob. I've tried all the firmwares but they did not work. At least they turned on the screen but it is all white. Now, I know that it is not physically damaged. Only the firmware (the most important part) is lost. :-(
Old 23rd Aug 2008, 9:13 pm
RockChip
RK2706
7E05002 0812
Screen
4315U-080320-080323-06-30
another chip
SAMSUNG 816
K9LAG08U0M
PCB0
Another chip
TAIWAN
TM54S816T-7
Old 24th Aug 2008, 12:39 am
this is a link to a firmware from the same company in china that also makes a version of the player you have
now it may be that that they uses similar hardware??? as they may have come from the same original factory
worth a try
also, have you emailed CDRking and asked them to try and extract a copy themselves and send to you, they seem hot on having downloads available
http://pasen88.cn/admin/shangchuan/U...6014229847.rar
Old 24th Aug 2008, 12:49 am
http://translate.google.com/translat...sl=zh-CN&tl=en
quite a few bits on this web site, and i thin also knob, maybe a newer firmware for your player, they call it the k818, there is a download at the top of the page
edit .. forget that knob, theirs seems to be an ingenics based version of this player!!!!
also the seem
  #16 (permalink)
Old 24th Aug 2008, 12:52 am
sorry to hijack, just posting this for knob
http://www.qqmp4.net/show_products.a...=K%CF%B5%C1%D0
this player can be found on dealextreme for about $40, its ingenics based and that chinese firm seem to have a download for firmware for it, just thought you may like to know as a cheap route into ingenics players
How Can Update Mp3/Mp4 in Recovery Mode (ADFU Device Mode) oxygen0077 Firmware 1 28th Oct 2008 2:15 pm
Can i changed the speaker of a mp4?? tcu212 Mods and Themes 1 3rd Apr 2008 9:16 am
Found the firmware that will work glacier mp4's speaker! tcu212 Firmware 0 31st Mar 2008 2:54 am
Glacier type mp4, need firmware that will work the speaker tcu212 Firmware 0 3rd Mar 2008 5:53 am
MP4 player with speaker? Lorne General Discussion 8 25th Sep 2006 2:31 pm
