Doubt about firmwares
Hello all,
I'm new to this and I have a question about firmwares. I have a Kingzon 8Gb that in the firmware info has the following: LSD_91N18H_A1 2007-10-23 9.1.52 2005-01-09 Can somebody tell me what type of firmware shall I look for it? Does anything related with 9.1.52 works? Thanks |
Hi fsportugal,
Welcome to the site. Unfortunately due to the large variation in manufacturers changing the firmware to match their player, not all 9.1.52 will work on your player. Actual fact, you'll have a higher risk of having a DEAD PLAYER than getting a firmware that will work on your player just based on the firmware version. Is there anything wrong with your player? If, not I would say leave it as it is and don't try to put another firmware on it. You only need to see the "DEAD PLAYERS" section of the forums to see what I mean. You don't want to go through the whole process of recovering a dead player by using an incompatible firmware on your player. |
| All times are GMT -7. The time now is 6:16 am. |
