-   -   Need Firmware for my MP4 Player (RK2608A) (http://mympx.org/forum/firmware/42752-need-firmware-my-mp4-player-rk2608a.html)
aTboZZ 14th Dec 2008 12:22 pm
der huso
du huso huso huso
FastKiller 14th Dec 2008 12:28 pm
OMG IT WORKS!!! THANKS A LOT!!! Is there a newer Firmware?
knob 14th Dec 2008 1:05 pm
Re: Need Firmware for my MP4 Player (RK2608A)
No, sorry, no more firmwares, you were very lucky to recover your player! :-)
FastKiller 15th Dec 2008 4:55 am
Thanks Knob!
But now I have the Problem...If I Charge my MP4 Player after 1-3 Minutes it say, FULL. Then when I play music or other it show me that is empty...
What can I do?
robouden1 25th Dec 2008 5:22 pm
Nice to read you where lucky to get your player working again.
I have also a similar MP4 player. I would like to change the theme as I did with a acu7515 chip set. Two questions:
- Is there a good theme editor for the rockchip 2608a?
- Is there still not a firmware dumper for the rockchip 2608a?
regards rob oudendijk
http://oudendijk.biz/2008/05/20/chea...no-mp3-player/
robouden1 31st Dec 2008 6:22 am
Originally Posted by knob";p=&quot (Post 55034)
Did the main menu look like this?:-
http://www.mympxplayer.org/pafiledb/.../etuc40wn7.png
Then try this one, it's worked for other members:-
http://www.s1fw.com/plus/download.ph...=861&cid=3
remember to remove any non-recognised chinese characters from the filename or it wont load into consumerUpdate and you will get firmware file error.
Good Luck
Tried the firmware but now it starts up with keys locked can not update any more any suggestions? Or other firmware that could work.
regards
