-   -   Looking Firmware for CTW500-JCT216D (http://mympx.org/forum/firmware/43028-looking-firmware-ctw500-jct216d.html)
stoker 19th Jan 2009 3:34 am
Helo,
I find last firmaware for ELBE MP501
Control: CTW500
Plate No.: No plate number :(
Screen No.: JCT216D
http://img509.imageshack.us/img509/2351/elbewk4.th.jpg
http://img292.imageshack.us/img292/3071/elbe2lo7.th.jpg
sndestroy 19th Jan 2009 11:31 am
Are you really sure that there aren't any pcb ID number in it?
It is often covered with stickers, or under the LCD flex connector...
BTW, if your player works OK then don't try to upgrade anything, its too risky.
stoker 20th Jan 2009 12:47 am
Re: Looking Firmware for CTW500-JCT216D
I attach photos all data of my device
http://img172.imageshack.us/img172/48/mp41wu5.th.jpg http://img238.imageshack.us/img238/557/pcbkw3.th.jpg http://img172.imageshack.us/img172/7523/pcb2qk8.th.jpg
my device is dead at this time,
http://img107.imageshack.us/img107/5175/deadzt7.th.jpg
I put the device in recover mode,
http://img261.imageshack.us/img261/5...overom5.th.jpg
after I flash with Action 4.05 Tools "Full Version 9.0.50 - 1.8 LCD" (same as the original version)
http://img301.imageshack.us/img301/6...n405hl7.th.jpg
and device remain on white screen :(
http://img301.imageshack.us/img301/6...reenkx2.th.jpg
I need to do something else?
Thanks!!!
sndestroy 20th Jan 2009 1:08 am
There is no firmware for that board on the net, but I've found this:
http://www.s1fw.com/plus/download.ph...aid=4105&cid=3
It's the only FW that seems suitable for that JCT216D LCD, try it.
stoker 20th Jan 2009 2:18 am
thanks for your answer but new error :(
http://img168.imageshack.us/img168/568/error1oc9.th.jpg
The error occurs with all firmwares tested.
Now the screen is black, AFUD device is detected, recover state is detected but Action 4.05 Tools fails.
EDIT:
the error disappeared,
I flashed with SCC-91020-2091N_1.8_JCT216d_5键.fw but screen remain white and device is not detected :(
