Rockchip rk2608a firmware
Old 15th Apr 2009, 6:48 pm
Default Rockchip rk2608a firmware
Please someone help me.
I have a 4gb 2.8" lcd touch screen mp4
like this
http://www.mp4nation.net/forum/viewt...af9c4411f6ad60
and menu appearance was like the second picture, where says 'For different VX858LE clones"
I tried this firmwares and many others but still haven't found it.
The chip is rk2608a
b97370 0840
The flash is samsung 831 k9gag0uom
This one is ok
http://mympxplayer.org/rockchip-firm...ted-df960.html
but the touch screen isn't working.
Old 27th May 2009, 8:37 pm
Hi, i bought a mp4 player from mercadolibre, i have tested over 25 firmware files, and some got me to the blank screen, others to the inverted screens and some others to the disabled touch screen.
my problem is solved, this is the from my mp4 player data:
THIS IS THE MOTHERBOARD OF MY MP4 PLAYER 2.8" (Onda vx858LE clone)
RK2608A Chipset
htc-039c-rk-v2 2007-11-02 CHEN ,
IT HAS A SAMSUNG 8GB MEMORY CHIP, WITH NO CAMERA
"Mini MP4 Player" startup screen
"Goodbye" shutdown screen
i uploaded this file, a big one, with the firmware that worked for me, the instructions and some other options that could work for you in case that the firmware that worked for me doesn't work for you.
http://www.megaupload.com/?d=40CGVXKB
I wrote the instructions in english so that many more people could use the file.
Old 27th May 2009, 8:38 pm
RK2608A Chipset
Old 27th May 2009, 11:21 pm
Default Re: Rockchip rk2608a firmware
what program are you using to flash your player? I have one just like it with the rk2608a chip, but no program I've tried is able to find the player, although windows sees it as a removable drive.
Old 27th May 2009, 11:44 pm
its included in the download link ( http://www.megaupload.com/?d=40CGVXKB ) its the rockchip product tools (consumer update v3.1.2.1), you can get your player in update mode by pressing the "M" button while the player is turned off and keep pressing "M" while you connect it to your pc. if your player was already updated and you get a blank screen or an inverted one, pressing "M" probably wont work, you will have to open up your player and apply the recovery method, (a link explaining its in the readme file in the download link) or you can search for in in this site.
Old 28th May 2009, 11:53 am
nice, but the MP3 player utilities still doesn't find any rockchip devices (although the rockchip usb device now shows up after that driver update) and I don't understand whether or not you can use the consumer update in your link to back up your firmware (which is what I truly want for my rockchip 2608a device) If you know a way, please send it my way! Thanks.
Old 28th May 2009, 12:02 pm
the consumer update tools cannot back up your current firmware, and from what i found trying to recover my mp4 device, it is not posible to back up the current firmware from a rk2608, i think it is posible with rk27xx devices, but not with rk2608 chipset, at least that's what i found. if your 2608 device is working firmware, do not update the firmware to try make your device work better, update it only if you need to recover it.
Old 28th May 2009, 12:54 pm
you have to use the dead player guide posted here somewhere. Hey ARMGUTX i tried your files on my player but they did not make the camera function on mine but i did find a firmware that has fixed it. I must have tried 30 or more firmwares on this Onda clone with no luck.
Old 28th May 2009, 1:03 pm
the file i tried from armgutx looked identical but the camera didn't work and the player just returned to the main menu after failing to initialize it. Link for firmware i used
http://www.youshare.com/Guest/8e252483c18f480a.rar.html
images of the player it worked on, rk2608a with 8gb Samsung memory
Old 28th May 2009, 1:15 pm
Hoskins41, glad you could make your player work!, my device had no camera so i couldn't test if the firmware works with the mp4 player with camera
Now that you found a working firmware for the mp4 player with camera i will download it, just in case i get one. thanks
i need firmware rockchip rk2608a muratgyte Firmware 10 22nd May 2009 8:12 am
Neen firmware for Diva FX-73 (Rockchip RK2608A B713750735) slavdodov Support and How To 2 4th Mar 2009 10:01 am
Looking for firmware: CD-R KING rockchip RK2608A blue Dead Players 5 18th Jan 2009 1:57 am
[solved] Looking for firmware rockchip rk2608a muratgyte Dead Players 2 26th Aug 2008 12:52 pm
Looking for firmware for ouyo rockchip RK2608A player bolbol Dead Players 3 4th May 2008 8:52 pm
