-   -   Itchee/rizone 32gb 2.6 mp4 (http://mympx.org/forum/firmware/43917-itchee-rizone-32gb-2-6-mp4.html)
Skezza 6th Jun 2009 12:01 pm
Hello guys,
Great to see a website out there to help tackle the problems that seem to arise with buying MP3/MP4 Players from Hong Kong/China etc. OK, i've not been able to find any details on these players. I've formatted it numerous times and it does seem to say there is still 32GB. HOWEVER, there seems to be other problems with it, mainly, the firmware is ridiculously shakey. No video that i've put on has played yet. only the video that came with it, and when i took that off and put it on myself it didn't play. :confused: I'm wondering if that is something to do with sync'ing because when I first owned it, I dragged and dropped my music files onto it, and it didn't play but then I used WMP to sync it and it was fine. Sadly, I can't find any details on the internet about it. I was hoping that maybe you could help me find some firmware. The chip says: SAMSUNG 907, K9LBG08U0M ,PCB0, YCA870CBC
http://img.auctiva.com/imgdata/1/1/7...63309885_o.jpg
Skezza 7th Jun 2009 5:19 am
4 Attachment(s)
OK. here are 5 pictures of the internals. I'm trying my hard to find details on Google, but not having too much luck, unless i'm looking in the wrong place. Please, anyone who can assist me, i would much appreciate it!
makd511 8th Jun 2009 2:05 am
ahh an actiona player with the 21 series in - these are very rare in chinese player
video should be drag and drop and needs to be AVI 320x240 XVID with mp3
as to why you cant copy the original back to play is odd, it must be your machine that is at fault here
i have a player using the same chip and all works OK
have you tried a different PC at all
Skezza 8th Jun 2009 4:20 am
I have not tried another PC. Is it worth using a PC loaded with Vista ? Or upgrading WMP 10 to 11 to see if Sync'ing using that helps? I've tried drag n drop quite a lot and it just doesn't seem to want to do it at all :( Which is why i think my firmware may be corrupt.
Any more advice you can give me?
Joe
makd511 8th Jun 2009 4:20 pm
if drag n drop wont work then sync aint gonna be much help - does the player actually work OK apart from this - these players are designed to drag n drop rather than sysnc anyway
trying another PC is needed really as you may have a virus or something - have you scanned the player at all
whaen you formatted the player di you replace all the original folders that were on the player - do vids need to be in the VIDEOS folder at all??
lolita 9th Jun 2009 12:54 am
> LBG
That's 4GB, not 32GB.
Skezza 9th Jun 2009 2:59 am
Thought so, and that is why it has been failing. Looks like they've conned us :D luckily, i didn't leave feedback as of yet, so i'll take out a disgruntled buyer thingy mabob. ;) Annoyingly, i've been trying to get videos uploaded and it has been failing miserably and i thought it was windows, but it is not, it is the player. The player seems to insist its 32GB and even formatting it won't sort that. Thanks very much for your help and BEWARE! kinhome88.
Thanks very much guys for your help! :)
And once again, I'm reminded why i don't normally buy stuff from China :rolleyes:
tobyjugg2 9th Jun 2009 8:26 am
Mine just sits there with the hello on the screen now. I tried to copy about 3.5gb of files to it to test it.
It is not recognised by windows when connected via cable.
Anyway to reset these and correct the size as there was with older models?
(The seller is no longer a registered user and Ebay has, as usual, removed the listing evidence. I will still get money back from paypal despite paypals every attempts to circumvent this.
tobyjugg2 9th Jun 2009 9:22 am
S1fw.com - Download ATJ2091/ATJ2093 Firmware
looks promising
tobyjugg2 9th Jun 2009 10:02 am
lol
www s1fw com /Actions-ATJ209X/index.html
