looking for Rockchip RK2706 (Onda VX747 clone) firmware
Old 5th Aug 2009, 1:43 pm
Question looking for Rockchip RK2706 (Onda VX747 clone) firmware
If there is someone that have buyed Rockchip RK2706 VX747 clone after 01 april 2009 please could upload the firmware on this site?
I'm sure that there is a new firmware for these players, I've seen some screenshots on ebay and menu is a bit different now.
The most important thing is that files BASE.RKW in folders SYSTEM and SYSTEM00 will be updated after 13 october 2008, like previous firmwares uploaded some months ago.
I hope that are been fixed some importants bugs like:
1. micro sd cards up to 1 GB are not recognized correctly
2. Volume from 1 to 0 decrease too quickly
3. Mp3 tags are not available.
This is the player:
Product name: RK27SDK
Major version: 1.2
Hardware type: 080422
TO extract the firmware:
copy the rkusb.tag file to the player main memory, once the file transfer is complete, disconnect the usb cable and switch the player off. With the player still switched off, plug the usb cable back in and wait for the computer to recognise the new second removable disk ( hidden firmware partition 60Mb), copy all the 4 required firmware folders + RKFSWFRC.FRC on your PC. Then delete rkusb.tag from your player, disconnect from PC and restart your player
Download rkusb.tag
Thanks.
Old 22nd Sep 2009, 1:35 pm
none has buyed this player from short time?
Old 27th Jan 2010, 5:29 am
I'm still looking for
Old 17th Aug 2010, 2:38 pm
After several months I'm still looking for a new version of this firmware.
Old 18th Aug 2010, 2:16 am
firmware does not get updated only different version for different player - even if they LOOK the same - do not look or wait for an update it will never erv come and the issues you want fixing are all standard bugs that will be in all - look, these player that you have are thrown out of back street factories for quick sale only, even more so nowadays as they also are being sold with hacked meory
you may see players that look like yours but its a standard design used by hundreds of different "factories" with different components - dont wait its a waste of time - sorry but what you have now is all you are ever going to get - these tech in these players is run of the mill and 2-3 years old now
Old 20th Aug 2010, 2:00 pm
Hi makd511.
In past year I have tried 3 firmwares for my player downloaded from the old site mympxplayer.org and they work! I remember that file BASE.RKW was older then mine and the firmware had some other bugs then solved in my firmware updated on october 2008. So I though that maybe some other player like mine could have a firmware updated after 13 october 2008....
Old 8th Jan 2012, 7:37 am
This is the player:
Major version: 1.2
Copy the rkusb.tag file to the player main memory, once the file transfer is complete, disconnect the usb cable and switch the player off. With the player still switched off, plug the usb cable back in and wait for the computer to recognise the new second removable disk ( hidden firmware partition 60Mb), copy all the 4 required firmware folders + RKFSWFRC.FRC on your PC. Then delete rkusb.tag from your player, disconnect from PC and restart your player
Download rkusb.tag
Thanks.
rkusb.tag updated, and I'm still looking for a new firmware. My main menu is exactly like the menu in the picture above.
The new menu is for example like this:
I'm still looking for a new firmware especially because I want solve the volume bug: at level 1 is still too high for me and at level 0 is mute!
Request: Rockchip RK2706 VX747 clone over Support and How To 5 4th Jul 2009 8:47 am
Request: Rockchip RK2706 VX747 clone over Support and How To 1 4th Jul 2009 8:47 am
Rockchip RK2706 VX747 clone bug over Support and How To 3 26th Dec 2008 2:09 am
how to install firmware for onda vx747 CLONE amonamarth87 Firmware 2 1st Dec 2008 4:11 am
ONDA vx747 clone players ARE NOT ONDA but rockchip makd511 General Discussion 7 29th Aug 2008 8:44 pm
