Firmware for Rockchip RK2708B, Dxt vx748, Samsung 925
Old 20th Aug 2009, 8:56 am
Question Firmware for Rockchip RK2708B, Dxt vx748, Samsung 925
someone knows where to find the firmware, drivers, and tools for this player?
Code:
rockchip RK2708B
samsung 925
K9LBG08U0M PCB0 ( YCE6L2BBC)
from player no info
Code:
Caratteristiche Tecniche
Chip Memoria Samsung Integrato da 4.0GB
Display a colori da 3.0" da 400x240 Px (256.000 Colori)
Fotocamera Integrata 5.0 Mpx (interpolati)
Formati audio: MP1, MP2, MP3, WAV
Formato Video: AVI, RMVB, FLV (Nativo) MPEG, MP4,Xvid, (dopo conversione)
Funzione ID3 Tag: visualizzazione del Titolo e Genere
Funzione Karaoke: (supporta file .lrc)
Radio FM Integrata (Frequenze Italiane)
Cuffie Standard:  Jack da 3.5mm
Microfono Incorporato
Slot espansione Memoria (microSD max 16GB)
Connettore: USB Mini A
Firmware Aggiornabile (a breve)
Funzione Sleep Timer
Indicazione Livello Batteria
Durata Batteria: Fino a 6 ore (in funzione del modo d'uso)
Batteria: LI-ION da 750 mAh
Funzione Plug & Play: non necessita di Drivers (W98)
Funzione Pendrive
Dimensioni: 100x55x12 mm: Peso 70 gr.
Old 21st Aug 2009, 1:47 am
but there is a support in this forum?
Old 21st Aug 2009, 11:46 am
Yes your firmware is on the player, just extract it and backup it up:-
Firmware Extraction for new Rockchip RK27xx series players.
Don't try any other firmware, there are no upgrades..
Old 23rd Aug 2009, 4:27 am
thx i have uploaded the folders backup
but for replace just copy file in the hidden partition?
Old 23rd Aug 2009, 5:36 am
Yes , it's easy on 27xx series Rockchips, just copy firmware back.
Old 23rd Aug 2009, 8:51 am
thx..i try the tools but don't work
i have uploaded 2 file
1 with 1 partition
2 with both partition and tools
Old 23rd Aug 2009, 11:16 am
You may have been supplied with the wrong tools, which tools do you want? there are a lot of tools on Download
Old 23rd Aug 2009, 5:16 pm
i try sflo and rockchip tutorial files.7z on mp4nation
http://www.mp4nation.net/forum/viewt...hp?f=24&t=4519
Old 27th Aug 2009, 9:06 am
How do I know the firmware version, just to write it in the download section where I uploaded the firmware file
Old 27th Aug 2009, 3:51 pm
is normal that i have 2 hidden partition?
ConsumerUpdate for Rockchip RK2708B NeoTheOne Mods and Themes 5 19th Jan 2010 2:48 pm
Pleease help meee!!! with my vx748 annoyng Mods and Themes 1 22nd Sep 2009 7:32 am
2.8" touchscreen mp4 rockchip 2608A & samsung 813 c dragonfly Dead Players 1 6th Dec 2008 10:22 am
I need the firmware for SAMSUNG 716 seba_carr Support and How To 1 14th Nov 2007 4:42 pm
FIRMWARE mp4 samsung 652 crakpa Dead Players 1 5th Apr 2007 7:32 pm
