Firmware for Rockchip RK2608 (Laser Mp351krf player)
Old 22nd Aug 2009, 5:33 am
Default Firmware for Rockchip RK2608 (Laser Mp351krf player)
help to find Firmware.
PnP Device ID: VID = 071B PID = 3203
Serial Number: USBV1.00
Revision: 1.00/1.00
Device Type: Standard USB device - USB2.0 High-Speed
Chip Vendor: RockChip
Chip Part-Number: RK2608
Product Vendor: (N/A)
Product Model: (N/A)
Tools on Web: (N/A)
Keenhight
MP351KRF v0.3 070809
HМ E237212
94V0 0805
ssd1928KL9
lu729bs
Toshiba x90810
Thank you in advance for any help.
Old 22nd Aug 2009, 7:05 am
Why do you look for firmware? Is your player DEAD?
Old 23rd Aug 2009, 5:54 am
yes, white screen.
Old 23rd Aug 2009, 5:59 am
follow this guide:-
You need to be in RockUSB mode first.
Double click on the remove hardware icon in your system tray.
If you are in RockUSB mode you will see the icon in the window like this:-
You MUST be in RockUSB mode to change your firmware.
To get into RockUSb mode
1) switch the player off.
2) hold down the menu key.
3)connect the USB cable
4) wait a few seconds
5) release the menu key
6) look for the RockUSB icon.
7) If you see the RockUSB icon, load the CORRECT firmware for your player using Consumerupdate program.
It this fails then as a last resort I suggest you do the Hard Reset already described to get into RockUSB mode and load the CORRECT firmware for your player using Consumerupdate program.
You will need to open your player to do the HARD reset, but only try this if you are confident with opening your player or you might break something!
You may find it easier on your player to try shorting the following 2 pins:-
These are the actual pins (posted on a Chinese website) which have also been found to need shorting to get into RockUSB mode, use tweezers or a small jeweller's screwdriver..
This would force the player into RockUSB mode upgrade mode, but you MUST look for the RockUSB icon
You will need to look for firmware RK2608 here:-
Download RK2608/RK2608A Firmware
I can't see any exact matches for your player you will need to experiment and guess, it's your only chance. Good Luck!
Tags
rk2608
Real Linux on an mp4 player ? RK2608 zgherlos Mods and Themes 16 16th Apr 2012 12:29 pm
RK2608 with upgraded firmware gvdgvdgvd Mods and Themes 13 16th Apr 2012 8:02 am
RK2608 Speaker Bug mustang50l Mods and Themes 8 18th Sep 2008 11:54 am
Any support for subtitles in video on Rockchip RK2608 MP4? Tikker General Discussion 2 19th Jan 2008 7:13 am
Free Laser Pointer Offer from UXCell.com wuffyFly General Discussion 2 24th Oct 2006 5:03 am
