-   -   Virus in RK27SDK (http://mympx.org/forum/firmware/44274-virus-rk27sdk.html)
nodeity 24th Aug 2009 8:02 pm
Virus in RK27SDK
Hey guys, First time user. How are you?
I just bought a 16gig RK27SDK from ebay, I wasn't expecting too much for the price $32.00 AU. I figured at the very least it could be used as a USB drive! as soon as i got it I charged it up and set to work figuring it out (no manual) which wasn't hard although I had to download rkusb.tag to find my firmware file. In it is an autorun.inf file and HOLDON.BIN niether of which I note are in the backed up firmware files I downloaded for comparison. More interestingly and very annoyingly, the inf file is a trojan for Win32/Conficker.B!inf.
Q1, does the firmware need an inf file or the HOLDON.bin Q2, is there anyway to shuffle my mp3's (looked everywhere but can't find it, I assume it's because of the firmware version, as some of the posts I've read do say it's there!) Q3, if I replace my firmware with the one in the "Rockchip_firmware_RK2706_RK27SDK.exe" file will it do any damage. Also what FW version is that file?
Your help will be greatly appreciated, Thanks
RK27SDK - Ver ID: 2.2 - HW ID: 080 722 - 16 gig
knob 25th Aug 2009 12:19 am
HOLDON.bin is ok. It is generated when you stop playing songs it stores the resumed song position.
To get random just play a song, then press and hold the back button and you will get a popup menu, just select play mode / shuffle.
Remove the "autorun.inf" file, it is used to launch the virus. Make sure you keep your firmware backup safe. You can try other firmware, but 90% chance it doesn't work.
nodeity 25th Aug 2009 12:27 am
Thanks for that Knob, that helped a lot. Actually, it' would be nice to be able to set the time and date too, they have the configuration in the setup, it just doesn't seem to want to stick, is that my fault or is there no joy there? thanks again
