Hi everyone!
I hope you can help me out. I've got the usual problem. Player had constant "Format Error" messages, I couldn't format it anymore or move files from-to the player, so: firmware flash
I made a dump file with the MP3 Player Utilities (Ver. 1.45) but that proved being useless.
So without further ado: I need the correct firmware. (I already have it in recovery mode)
After days of browsing through all sources and not finding anything, help me MyMpx, you are our only hope.
Here are the specs: (no board id anywhere to be found)
4GB MP4
Wilson Co. Ltd.
Firmware 9.1.51 (killed it)
underneath the TFT on the green board there were these numbers:
HH15ST-3000G
V2.0
071011
Chips are:
big: Samsung 716 K9LAG08UOM PCB0 CSFD10PAC
medium: ACU7515 G2263CA C4S
small: (SPT) SP3767AHN 07GS26
on the backside of the TFT is a little sticker reading: 471E10
also on the back of the TFT there was another sticker:
M470091501.36 $32T0FA0000279
Inside the casing it says V205 and apparently the "brand" got to be "Wivo". Note the pic:
I did find the "manufacturer" or distributor and the product:
深圳市众芯科技有限公司
I tried to contact them but they never got back to me
Well, that's about it. If you find anything and can help me, beers are on me!
