Search for Firmware
I search a firmware for my ipod clone .... I donīt like the Firmware itīs so stupid itīs slow and so on... Itīs a player from CBD Co., LTD 2009-07-28 9.5.54 also som song titles are not the original they stand... y with ü-dots and then 2 normal letters then a space and from begin with other normal letters but the y with ü-dots believe
You'll have to open up your player and post the board and plate ID numbers to better your chances of finding a compatible firmware for your player.
can you describe me how can i open my player because itīs an ipod nanao clone and there ar no screws.
There should be a small panel down the bottom where you connect the USB cable into. You should be able to remove the plastic cover under there and that should then show you the screws.
Can you post some photos of your player just in case? |
I am able to open the bottom but i am not able to do something else....
her are two photos... http://i48.tinypic.com/9i9w6b.png http://i48.tinypic.com/bgzr54.png |
That white plastic cover at the underneath of your player should come out then the board should slide out from the bottom. Try it and let me know.
i donīt get the board out i tried it with tweezer but nothing... is there a trick?
Hello, just use headphones jack. 1mm plastic layer is sticked on plastc cover with screws. You get it out simply.
| All times are GMT -7. The time now is 9:14 pm. |
