Need Firmware for generic 2.8in touch MP4
As the title says,I need new firmware for it.
In the settings menu there's a button for "update firmware" but when I press it and plug it in to my PC windows device installer comes up and searches for the drivers but can't find any so I need firmware and a program that will install it,Here's a picture of the exact one. I also checked in the settings tab under about and it says: VER: 00.00.0000 Date: 2009-01-09 And that's all it says I have no information on this brand or anything. http://www.menstech.com/wp-content/u...ipod-touch.jpg |
Firmware
You have a Rockchip-based player.
Try to find the firmware for the player with the similar appearance and main menu, and then install it to your player. |
Thank you very much,I looked and I didn't see any with the same picture but i did find this one,I think it's it because of the version number but Im not sure and i don't want to get the wrong one and brick it.
Download Rockchip Firmware: RK2606A ver00.00.0002 - MyMPx |
Firmware
You have a sylvania touch screen mp3/mp4 player. Mine is identical and is 4 gig. Hope that helps
Thanks for the info but sadly that is not it,They do look exactly the same though.
Wizard is right it's a rockchip but im not sure which one. |
Player
How to check the generation of your Rockchip:
try to make a firmware backup using a .tag file (follow the instructions from this forum) if this procedure will be successful, then you'll have a firmware backup :) and your chip's generation is RK27xx; else the generation is RK26xx (because it's still impossible to make a backup from RK26xx-based player) |
I opened it and the chip says "ROCKCHIP" RK2608A and I can't make a back up so do you think it's safe to update the firmware? and If I were to update it what program would I use? BTW thanks for all the help so far.
| All times are GMT -7. The time now is 12:28 am. |
