I need firmware mp6 MAX v8
Old 2nd Feb 2010, 12:04 am
janbaz's Avatar
Arrow I need firmware mp6 MAX v8
hi
I USE FRM TOOL I need firmware for MP6 MAX v8 model
Old 2nd Feb 2010, 1:19 am
Do you have more information about the firmware? Like the board ID, Plate ID or LCD ID numbers? Those would be helpful and you can find them out when you open up your player.
Old 3rd Feb 2010, 5:20 am
janbaz's Avatar
Arrow
sir plz detail what mens board ID, Plate ID ???
Old 15th Feb 2010, 3:33 pm
You'll need to open up your player. Then note down all the numbers on the board and side of LCD screen as well. Then post them here and that will help determine what chipset board your player uses.
Old 26th Feb 2010, 3:05 am
Dear Janbaz
You have to open up (dismantle the unit i.e. open the screws and pull apart to see the electronics inside) and note the numbers written on the different parts like:
Side of the screen number (LCD), the number on the 2nd largest chip (called MICRO by us or MASTER by Chinese) and the number written on the circuit board (PLATE). If possible also take the number on the largest chip (NAND FLASH).
These are very important to find a firmware and the tool required since the manufacturer information is not available in Chinese MP3/MP/s
Note: if you flash a wrong firmware you would end up in disaster.
Hope this will help
Mabboseg
