-   -   My Me2 1.5" Mpx player firmware (http://mympx.org/forum/firmware/44992-my-me2-1-5-mpx-player-firmware.html)
Trishen 5th Feb 2010 10:45 am
Can anybody tell me where i can find a flash firmware for this type of Mp3\mp4 player. Its branded under Sakyno where i am, It shows nothing on the box about the Board details. Help i really want to get this thing working. If there is any firmware please Send me a Link, thanks it will be highly appretiated
Binh@MyMPx 5th Feb 2010 12:39 pm
Please try to open your player and post the numbers on the board and back of the LCD screen. This will help us determine what chipset it uses and the version etc....
Trishen 6th Feb 2010 10:15 am
Hi, thanks for replying. I have a problem with the Mp4 player itself. there is a hard metal covering on the it (sort of like the new iPod nano 4th generation). Now i cannot open the Mp4 player to check the board as I am scared I might damage the board, So i can try that... If you can help it will be much appreciated
Trishen 7th Feb 2010 7:55 am
I found this on the board ATJ2093H Fc222FA 5CQ.
Where do i find the right Firmware for this type of Board, and if so, I'd like to modify the firmware so It can take a few applications and themes. Please Reply and I am total Newbie to this, I'd like this thing to work properly so i can at least use it. :) thank you
