Q-BE+ firmware
Old 7th Feb 2010, 5:21 am
Exclamation Q-BE+ firmware
I'm looking for fimrware for SupportPlus Q-BE+. I can't find any on the net, so I hope that somebody can help me.
Old 7th Feb 2010, 11:44 am
Hi there and welcome to the forum.
You will have to open up your player and look for the board and plate numbers printed on the motherboard of the player. Post all the numbers you see. There should also be a number on the LCD screen as well, please also post that. That will give us a better idea what chipset your player is and helps in determining a compatible firmware for your player.
Old 10th Feb 2010, 1:31 am
Hi and thanks for youre quick reply
Sorry that it took so long, but the player is from a friend and I had some problem to kontakt her. The number inside the player is Sigmatel STMP 3507.
PS. Sorry for my bad englisch, I'm from Poland and I'm still making a lot of mistakes.
Old 3rd Sep 2010, 10:04 am
Default Q-Be+ 2Gb with Sigmatel STMP 3507 firmware
Hello all!
I have a player Q-Be+ 2Gb with Sigmatel STMP 3507 firmware.
Exactly, I don't have STMP 3507 firmware, because, mistakely I delete it.
Somebody have a firmware for this player?
Thank you in advance!
Old 8th Nov 2010, 10:21 am
Default q-be+ 1gb is sigmatel1307
now the picture,
the question:
where can i found the firmware?
thank
Old 8th Nov 2010, 10:35 am
Default the same
My Q-Be+ is the same.
I have that problem to.
Old 8th Nov 2010, 1:41 pm
lsusb say
Bus 001 Device 007: ID 066f:3500 SigmaTel, Inc. Player Recovery Device
Tags
firmware, q-be+, software
