-   -   how can update firmware anyka 32gb (http://mympx.org/forum/firmware/45005-how-can-update-firmware-anyka-32gb.html)
kreuzberg 7th Feb 2010 1:42 pm
i have anyka 32gb fm and 2mpx camera pmp player i have problem if i hear mp3 many times it stopped from alone and i will change the firmware how can i do it?
makd511 7th Feb 2010 5:04 pm
can not change firmware - do not try - you have cheap no brand player
check to make sure the mp3 files are OK they may be corrupted especially if they were downloaded - check the tags
Binh@MyMPx 7th Feb 2010 11:12 pm
Also, does this happen when you listen to the radio for a long time or when you watch some video files too?
kreuzberg 8th Feb 2010 4:30 am
no only mp3 files sometimes goes perfeckt but most times some songs stopped from it selfs i dont know why for example mp3 song nummer 1 stopped if i make again this song goes well then another lieder again stopped and sometimes well i dont know what can i do ?
