-   -   Need firmware from bbs.mydigit.cn (http://mympx.org/forum/firmware/45072-need-firmware-bbs-mydigit-cn.html)
javivi79 26th Feb 2010 1:51 pm
I am in need of a firmware file located here:
求固件急,板号是 ESR171-HJ009 | MP3/MP4固件求助区 - 数码之家 - 专业数字产品爱好者社区
firmware is ESR171_HJ009_MMFSN724V_BYD_ST7787_12SCN_V1_5_07022 8_01.rfw
I've tried to register on this site, but they require an invitation
Help me to download please
mabboseg 26th Feb 2010 7:25 pm
javivi79
I have downloaded your firmware How shall I pass on to you ??
Mabboseg
javivi79 26th Feb 2010 7:54 pm
Send me to me email javierantonmontejo@hotmail.com , please
Where did you download it?
javivi79 26th Feb 2010 10:49 pm
i have downloaded it but do not work.
My mp4 is ijoy i-2467y
http://img200.imageshack.us/img200/5...4player.th.jpg
plate:ESR171-HJ009 A_V1
board: rk2608a
screen: bkl-lw1029a yh-bl070001 a 07/08/25
i need firmware, help me mabboseg
mabboseg 26th Feb 2010 11:30 pm
Downloaded from www.mydigit.net.cn. You know what .. I used up all my coins. I will send it you from my email (safe).
Is your Player DEAD?? If it is still working than DON"T upgrade with another firmware, for it might not switch on again. A slight change in firmware will kill your player, I am talking from experience OK. If it is still working than try and format with FAT32 (Windows) to get the correct size of your memory for the memory may be hacked. It should work fine after that. I should tell you that the cloned players from China are very good in hardware design but the only problem is the hack in program to show larger storage space. Once you are about to pass the correct storage space ....the problem starts.
You have to get exactly the correct firmware and it is not easily available outside China. As you would know that S1fw site is DEAD now.
I thought this will help
Mabboseg
mabboseg 26th Feb 2010 11:50 pm
javivi79
I have just sent you the email with firmware.
I don't know about your player yet ...they all look alike from outside but are very different inside. You will have to dismantle it and see the board design and the chips used. After that you will have to logon to mydigit.net.cn and look for a similar design in the forums there. Once you have found the right one than you will have to either pick the firmware if it had worked with the original poster, or place a NEW post in that forum. China is a very big place (much bigger than the rest of the world in electronic sense), so some one will answer back. They are very easy people to deal with (girls are even a lot friendlier and they come into forums more than boys on electronics subjects).
Take Care
Mabboseg
