-   -   III Generation 1.8" TFT MP4 Player (TM-620) Firmware Request (http://mympx.org/forum/firmware/45195-iii-generation-1-8-tft-mp4-player-tm-620-firmware-request.html)
JacobB199 9th Apr 2010 8:35 pm
Sorry im new here so sorry if im posting in the wrong place but i need the firmware for III Generation 1.8" TFT MP4 Player (TM-620) TM620 is the model number and you can see image hererhttp://image.made-in-china.com/2f1j0...er-TM-620-.jpg thanks for any help JacobB199:o
Binh@MyMPx 11th Apr 2010 1:33 am
You'll have to open up your player and post all the plate and board ID numbers so to find a compatible firmware for your player. Unfortunately the model doesn't help as a lot of these players have the same outer casing, but the board inside is different.
JacobB199 11th Apr 2010 2:55 am
Their is a chip in the back and it has these on it-
Samsung 007
k9gag08u0d
pcb0
and they where the only numbers i could find on it. hope this is what your looking for.
Thanks for helping JacobB199
JacobB199 11th Apr 2010 3:01 am
And the firmware version currently on it now is
2009/09/12
9.5.60
as202b
2009/10/15
hope this helps xDD
admin 11th Apr 2010 10:24 pm
That's getting close now.
On the board (you'll have to open up your player) as well as the side or back of theLCD screen, you should see some numbers. Such as ATJXXXX etc....
JacobB199 11th Apr 2010 11:49 pm
I found the numbers on the screen. here they are
ql-bl1012 091113
hope this is what you need. thanks jake
