Need firmware for Rockchip RK 2608A
Old 19th May 2010, 5:01 am
Armani5's Avatar
Question Need firmware for Rockchip RK 2608A
Hello, can anyone help me find firmware for this player :
Here is all numbers from chips inside :
Rockchip RK 2608A B72901 0737
and another :
Samsung 737
K9LAG08U0M
PCB0
Old 19th May 2010, 6:42 am
I have the same player by looking at the outer casing.
I'm not entirely sure what the firmware version is though. I'll need to dig it up as it's stored somewhere..............
If I find it, I'll let you know.
Not sure if I can extract the firmawre from the player though.
Old 19th May 2010, 6:51 am
Armani5's Avatar
Ok, thank you very much
Old 19th May 2010, 11:10 am
Hi Armani
Why do you need the firmware? is your player dead?
Be very careful there is no quarantee the firmware will work, even if from another player that looks exactly like yours, you are in risk of bricking your player for good.
Old 19th May 2010, 11:15 am
Armani5's Avatar
Hi, yes its like dead... when switch on it showing blank screen
I know about risk but think firmware upgrade can help me
Old 19th May 2010, 11:46 am
ok. here is the omega v88 firmware, the player looks just like yours:-
http://mympxplayer.org/firmware-rock...lst-df739.html
heres a photo of it:-
http://acemusicplayers.com/index.php...emart&Itemid=1
or teclast c260 firmware:-
http://mympxplayer.org/firmware-tecl...020-df639.html
Old 19th May 2010, 12:17 pm
Armani5's Avatar
Thank you very much I tried Teclast c260 but he also dont work (showing blank screen) but I dont tried Omega v88 because I dont know what to do with .lst file... Can you tell me what to do with it?
Old 19th May 2010, 12:33 pm
You don't need the .lst file, that's for modding the UI with Rklogoedit.
The .rfw is included in the download.
Good Luck!
Old 19th May 2010, 12:46 pm
Armani5's Avatar
Now tried Omega v88 but unfotunately also nothing only one change that with Teclast c260 keypad dont worked now with Omega v88 keypad working (lighting red). Big thank you for trying help me
Old 19th May 2010, 12:55 pm
Another firmware ACME V500X:-
http://mympxplayer.org/rockchip-firm...eme-df826.html
ACME V500X 4Gb Flash Digital MP3 Player / by Manufacturer / MP3 Players / Digital MP3 Players
Button arrangement is a bit different but it is still a touch screen.
Need firmware for rockchip 2608a screenfpc 007B3 phatdogg11 Dead Players 0 8th May 2009 8:16 am
How to extract RockChip 2608a firmware slavdodov Mods and Themes 0 2nd Mar 2009 7:00 am
Looking for firmware ROCKCHIP RK 2608A B897370814 dada80dada Dead Players 16 23rd Oct 2008 7:44 am
Looking for firmware Rockchip 2608A NP2801 CATE: 2007/04/14 Pavel Firmware 2 16th Aug 2008 10:20 am
firmware for 2.8" Rockchip 2608A B72890 0737 ahmetbyk Firmware 7 12th Aug 2008 12:25 pm
