Restore Firmware MP4 Titan
Old 26th May 2010, 6:13 pm
Unhappy Restore Firmware MP4 Titan
While I was updating the firmware something happened and It was not completed, and now the mp4 shows titanīs logo but then the screen goes gray, I tried updating the firmware again with the consumer update but it displays this message "Operative system error".
In the mp4 I can add files, Windows shows the device in My Computer.
Please indicate me how to restore firmware
Titan 2GB MP4 US-71 0804A
Rockchip RK2608H2G0805
Old 26th May 2010, 9:45 pm
Do you get the player to show on your computer as "Rockusb device"? You should have the original firmware on the cd that came with the product, so that is not a problem. To get the player to appear as Rockusb device to install new firmware, simply move the power switch to the off position, hold down the play/pause button, connect the usb cable, and keep holding down the button until a usb connection is indicated on the computer. There should then be no problem with using the consumer update program to restore the firmware.
Old 28th May 2010, 6:56 pm
I tried that but It doesn't work I get the same message "Operative system error".
Tags
firmware, mp4 titan, mp4 us-71, restore, rockchip
rk2706 -> restore firmware -> red screen Aiken Dead Players 2 16th Sep 2009 10:30 pm
Titan 2gb stmp3638 frankjasmin Dead Players 0 5th Aug 2008 11:42 am
Looking for firmware: MP4 Titan 4.0 Gb andreneri Dead Players 1 14th Aug 2007 8:59 am
Firmware needed to restore mp4 Samsung 725 vp99 Dead Players 0 1st Aug 2007 9:30 am
how to restore Alltronix firmware S1 Version 3.2.13 Cimot_1803i Dead Players 0 24th Nov 2006 6:07 am
