hellllllp pelease
my mp3 player needs a firmware upgrade or something it was advertised as 32 gb ( memory hack );) fixed that but now it keeps messing up loses files format error black screen lock up one chip on it is an ak2025c
some more info
Device Name: +[E:]+USB Mass Storage Device(ACTIONS HS USB FlashDisk USB Device) PnP Device ID: VID = 10D6 PID = 1101 Serial Number: 4512482ADF0FE Revision: 2.00 Device Type: Standard USB device - USB2.0 High-Speed Chip Vendor: Actions Chip Part-Number: ATJ211x Product Vendor: (N/A) Product Model: (N/A) Tools on Web: (N/A) any help is thanks |
Where did you get the FW for you ATJ211x ?
| All times are GMT -7. The time now is 1:37 am. |
