Hi. Trying to find upgrade to firmware
If anyone could help it would be great.
I have a mp4 player, it is Rockchip based, in the System/About menu, it says Ver 01.09.0100 Date 2008-06-24 FlashMem 0-1868mb CardMem 0-0mb Its touchscreen, has a built in speaker on the front to the left, and a circle with a red square light to the right. The on off switch is on the top at the top side right, and it has a card slot on the underneath bottom side. On the far right of the screen there are 5 buttons, vol +, vol -, Menu, Note, and Rec. The player does work fine and OK, just wondered if there was a firmware upgrade for this player, due to me trying to write a GameBoy emulator for it, and possibly a ZX Spectrum emulator. Just wondered if the firmware was upgraded to make the player run more efficiently, due to the crappy lag my beta versions are running at. Thanks. |
| All times are GMT -7. The time now is 1:45 am. |
