Firmware i-Platinum 2 GB 1,5" bought from Uxcell
Old 31st Dec 2006, 2:32 pm
[quote="tropicofcancer";p="17236"]I have a new full metal platinum and it is very slow and arduous to access the music folders (not helped by a dodgy MENU button). Also when I try to select a music folder to play, it doesn't play it but goes back to the track it was on before going into the folders. I wonder if this might help or if it would just risk crashing my player.
I have a Glacier that has the same problem with the music folders. I have found that to get to different folders after selecting the folders menu hit the >> befor it loads and it will jump down one folder after they load but will remain in the folders dir.
Old 1st Jan 2007, 2:53 pm
Default Re: Firmware i-Platinum 2 GB 1,5" bought from Uxcell
HI, Yes I have the same problem with my Super i Plat 2 G Player!!
I a m not really happy with it as it will take a lot of effort to get this thing up to scratch. Particularly the firmware, its so god damned Chinese :shock:
The battery is sh## :evil: a dodgy 180mAh which lasts half an album and then need to recharge, i want to at least get one of the 330mAh versions
The Uxcell site for the Super i Plat is not showing that the screen is sideways and the click wheel is as well, which is a huge pain in the frelling arse!
otherwise it is an mp3/4 player that works??????....................................... ..................... :cry:
Cheers
Joffa
LKD 9702 01
2006 - 10 - 25
FW 9.0.48
2006 - 9 - 12
Logic chip - ATJ 2093H
Samsung 2 G memory
Battery 180 mAh
Old 5th Jan 2007, 10:09 pm
Cheers
Joffa
LKD 9702 01
2006 - 10 - 25
FW 9.0.48
2006 - 9 - 12
Samsung 2 G memory
Battery 180 mAh
Hey Joffa, can u upload ur firmware for this player listed please I have the same atj2093h 2GB nano lookalike, but I need the firmware to restore it, Please can u upload it or send it to me, I would really appreciate it. My player is only 2 days old and it needs to be restored.
I can not find the firmware anywhere online.
Old 6th Jan 2007, 12:37 am
Hi BetaBoy,
As far as I know, to extract the FW I need a new version of the extraction software that does not exist yet, apparantly the FW dump will be corrupt, if I try it with the current version, until the guy who invented the software updates it for FW 9.0.48 and above (newest FW types) YES it BLOWS!! :cry: I am so wanting to fix the issues that are so obviously FW problems and trick up the themes and images, Like a lot of other people with our FW
we are to wait a little longer until the new version is available!!
Sorry for any disapointment
Joffa
White Super i Platinum 2 GB
Logic Chip
ATJ 2093 H
F8200FA 59E
LKD 9702 01
2006 - 10 - 25
FW 9. 0. 48
2006 - 9 - 12
Memory
Samsung 640
K9LAG08U0M PCB0 FEI848AX
Battery 3.7v 180 mAh
USB 2.0 A to Hirose 4 pin flat
Old 6th Jan 2007, 12:46 pm
hi joffa,
thanks for responding, like u said, all i can do is wait.
i am just glad i found someone with a working mp4 player with the same chip as me.
thanks
Betaboy
Bought 2BG Glacier from UXcell but alittle worried mark04912 General Discussion - Uxcell.com 2 10th Jul 2007 7:25 am
Metal Platinum V3 from UXcell? DimaMp4 General Discussion - Uxcell.com 2 6th Jul 2007 6:29 am
uxcell i-platinum 2gb 1.5" firmware and dump files dfales13 Dead Players 0 9th Apr 2007 3:46 pm
New Uxcell Platinum player jazzrascal General Discussion - Uxcell.com 2 19th Feb 2007 1:10 pm
Chargers for Uxcell Platinum bluetooth88 General Discussion - Uxcell.com 4 6th Feb 2007 11:51 pm
