which player from uxcell?
Old 13th Dec 2006, 10:00 am
Default which player from uxcell?
first off, hello everyone I'm new.
I am thinking about purchasing a new player from uxcell. The glacier player looked perfect but I missed it, so I need your advice.
what do you think about Palladium and i-Nickel players?
anyone know how long do their batteries last? everytime I read about them it's like 2-3hours, but screen not turning off is mentioned, so it sounds like bad firmware or even more likely an incompetent user
i want it to have 3.5mm jack and be small, light, sturdy(I'll use it on a bike too), good battery life.
thanks for other tips too.
PS. or should i wait for another batch of glaciers?
Old 13th Dec 2006, 11:21 am
Que Que is offline
Speaking for myself: I'm glad I took the Glacier, it is worth the wait if the batch ran out. It also depends what you want to do mostly with it. For movie watching go for a bigscreen like the palladium or similar, but low battery life comes with those big screens.
The Glacier and players like that run longer on a load, advantage of the Glacier is it uses a nokia-type BL-4C battery, widely available for a couple of dollars and with capacity till 1700 mAh, which in theory should last 30-35 hours of regular music playback.
Old 13th Dec 2006, 11:57 am
Default Re: which player from uxcell?
i have two Rhodium's they one for work and one for play, they use an sd card so i can quickly change between the two. it also has a very good 2" screen that plays avi (xvid) files at 24fps opposed to the 12fps of amv players. it also has a user defined EQ.
Battery is about 3 hours Continuous music playback but i have orderd a ipod nano battery that is 900mha. not sure if it will fit yet though but it was only a few pounds
Old 13th Dec 2006, 7:28 pm
^^ have u tried stickign a sd card thats 2gb+ into ur rhodium player?
Old 14th Dec 2006, 12:27 am
got one on order, will let you know soon
4gb Glacier mp4 player from Uxcell kjparker General Discussion - Uxcell.com 4 2nd Mar 2009 10:27 pm
NEW MP4 Player on Uxcell - Spectrum tiobilyy General Discussion - Uxcell.com 8 6th Apr 2007 1:44 pm
Best mp4 player from uxcell? FMPman General Discussion - Uxcell.com 2 15th Feb 2007 7:30 am
Avi Player from Uxcell whitedragon General Discussion - Uxcell.com 11 12th Feb 2007 2:10 pm
Player return to Uxcell Joffa General Discussion - Uxcell.com 2 20th Jan 2007 3:55 pm
