Probably original nokia, all low cap? The ones I bought are Maxcell Lithium Polymer, maybe the Lithium Ion's are lower capacity? Someone posted here he fit a bl-5c, but with altering the case to make it fit.
Re: Glacier: questions re: battery
Hi, What type of player are you refering too, for these batteries to fit into??
Just curious?? what are the physical size dimensions of these particular batteries Cheers Joff |
Joffa, the topictitle says "Glacier", a google for the bl-4c dimensions gives 53.10x33.40x4.50 mm. You posted before you had your morning coffee, right? :D :D (just kiddin')
I also want to find a good source for an extra Nokia battery for my Glacier. The 2 sources from the Netherlands selling 1700mAh batteries do not sell worldwide! I Googled it and could not find anyone online selling 1700mAh versions of this battery. Which leaves the 900mAh versions. Now I was told here in these forums that the Glacier can fit a BL-4C or a BL-5C. Now I read "not the BL-5C without modifications to the player".
Can anyone give me a clue as to what my best options are, for getting a spare Glacier battery? (Don't want to have to modify anything) |
[web:f7d5e985fc]http://cgi.ebay.nl/Nokia-6100-6230-6210i-6600-6630-Akku-Li-Polymer-1700mAh_W0QQitemZ230037164278QQihZ013QQcategoryZ30 416QQrdZ1QQssPageNameZWD1VQQcmdZViewItem[/web:f7d5e985fc]
It does say Verenigde Staten (United States) in the posting tariff section, €4,10 without or €8,70 with insurance. It is a German shop selling Maxcell batteries. |
| All times are GMT -7. The time now is 10:43 pm. |
